Help: 2012 Prius V 140k Blown Head Gasket - Fix or Sell
Discussion in 'Prius v Main Forum' started by KarunaYW, Jan 14, 2025.
  1. KarunaYW
    KarunaYW New Member
    Oakland, CA
    Hello everyone,
    I have a 2012 Prius V 140k. (I got it at 135k but that's not so important). According to CarFax, previous owner really took care of it and did all the services with Toyota Service Center actually. Changed battery at 100k, replaced tires at 119k. I recently change the spark plug and ignition coil.
    The check engine light was on a month ago, I took it to the shop and replaced the spark plug and ignition coil. Now thinking back, it might not be the reason that the check engine light was on. The car started having rattling sound soon after, and I brought it to the first mechanic - he didn't seem to know what's going on (he said it was the transmission). I went to another shop (multiple people recommended this shop) to get a second opinion. They seem to know better definitely. They say that it is likely a blown head gasket, and after inspection, they confirmed it. That made a lot of sense after doing some research. Not only the symptom matches, and apparently it is a common problem for gen 3 Prius.
    The shop says that it will cost around $5200 to fix. And they say that I should really think about whether I want to fix it at all.
    I am very new to owning a car. I am scratching my head thinking about it. Fixing means that there might be more to fix, but shouldn't Prius be super reliable?? Selling and rebuying another used car, a lot of headache first of all, and how would I know anything like this wouldn't happen again? Even a 90k Prius could run into battery replacement soon. I don't think I am up for buying a new car or a nearly new car at this point (unless you all can convince me....).
    Any opinion is very much appreciated!!! Thank you!!!!
    Warmly,
    Y
  2. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    Any car eventually requires repairs.
    With careful handling, the start date of repairs is a long way off.
    The problems in the Gen3 engine and the Prius V are the same.
    The weak link of this engine is overheating, deformation, failure of the engine gasket, leakage of coolant, piston seizure.
    When replacing the engine, the car will please you for a long time with careful handling.
    5200 for such a repair is probably expensive, only when there is no alternative option.
    And more!
    Check out this fun thread about a blown gasket, it will give you some enthusiasm for solving problems.
    fix you a head gasket | PriusChat
    #2 MAX2, Jan 15, 2025
  3. Brian1954
    Brian1954 Senior Member
    1,699
    663
    South Central PA, USA
    That is a terrible thread to link to. The OP in that thread does not know what he is doing based on the questions that he is writing.
    The OP in this thread may want to consider a rebuilt engine from Hybrid Pit if he wants to repair his present car.
  4. Leadfoot J. McCoalroller
    7,825
    7,291
    Pennsylvania
    2018 Prius c
    A new Prius is very reliable and tends to stay that way for years.
    Once those years are over, they are like any old car: less reliable.
    The real difference is that the Prius is very complex. It's hard to make complex things reliable. When they do, they seem like magic. When they inevitably age and break down, the repairs are expensive compared to the simple cars.
    Not an endorsement, but it does sound like the shop you're working with actually has your interests at heart.
    Brian1954 likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,486
    5,811
    Texas Hill Country
    Your best bet would be a professionally rebuilt engine. Which is what $5200 or far less should get you.
    Given you only got 5k miles out of the car, it could have been sold with hg sealer to mask the problem. Not saying this happened for sure but it has occurred in the past.
    It may be smart to contact Gasketmasters who would have all options available. Might mean driving to them but they might help your decision making. I would go to the original location.
    As is the car is not worth much.
    Toyota Prius Repair Shop Manteca, CA | Gasket Masters Inc
  6. Mendel Leisk
    40,457
    Which likely means he never did EGR cleaning *, had oil changes every 10k miles (too long), may have damage engine underapanel, and neglected brakes.
    Very likely. Was the code P0301? That indicates misfire at cylinder one. Cylinder one is where the head gasket usually starts leaking coolant, into the combustion chamber.
    Yeah tough call. $5200 is steep though. Replacing the head gasket, and all the other pliable gaskets/seals encountered in the process, is typically around $2500~3000 USD. This is assuming the head and block interfaces are still flat enough to be within spec, and machine shop work is not needed. With your miles, and getting on it right away, that's likely the case.
    Still, having a 2012, it'll have low-tension piston rings in the block. Toyota wanted a few tenths of a mpg, went with these rings, and they've proven prone to develop oil consumption, starting around your miles. So replacement pistons rings may be worthwhile. If done while the head's off, maybe another grand USD? Or a new short block can be swapped in (brand new bottom end, everything between upper oil pan and the head), for about $2K usd for the part. It will have the revised (higher-tension) piston rings, in revised pistons.
    * I have a half-backed theory, that this is why the head gaskets blow. Others may be along shortly, to say it's piston rings, head gasket design, water pump failure, and so on. Anything but EGR.
  7. rjparker
    9,486
    5,811
    Texas Hill Country
    The question was fix or sell. At this point the cause if irrelevant - the solution is the question.
    Pro built replacement engine for less than $5200 installed. Otherwise selling it will incur a big loss.
    #7 rjparker, Jan 15, 2025
  8. Mendel Leisk
    40,457
    The solution should involve remedying the cause, to avoid another failure.
    eleison likes this.
  9. bisco
    51,011
    sell
    eleison likes this.
  10. eleison
    eleison Junior Member
    Chicago
    Old cars... there will be another failure, somewhere.. somehow... I have a 2012 which I and my dad swapped a JDM engine on to. It's been working out well for the past year (I'm extremely happy about this), but logically, a new car is probably the better deal. I love my 2012, but the biggest thing that bug me is that newer cars have better safety features. Apparently, my car does badly in the IIHS slightly offset collision test. Also, I heard the brakes will be the next thing to go. My car has 275k miles. Truth be know, I'm actually looking for a new car (but I've been wavering because I'm extremely allergic to car payments.. and increase insurance costs :)
    Fix the car for 5k? How long will the 5k fix last before something else comes up? I think if you fix the car, it should last/keep it for another 3 years?? I think 3 years is the break even point? But then with 5k, can't one just buy another used prius (same model year? etc?) or just for a little bit more? If I do get a new car, I'm assuming I can only get 3k for my old one which is running very well..
  11. rjparker
    9,486
    5,811
    Texas Hill Country
    With full coverage the 2012 v and a 2022 Rav4 hybrid have almost the same insurance costs through my USSA coverage. Removing coverages and buying liability only on either is an option but liability is where you are exposed if you hit a $150,000 car or worse yet hurt somebody. If you have any assets it costs money to protect them.
    I agree the advanced safety features are great, especially blindspot, lane keeping and rear object detection when in reverse. I have yet to activate automatic braking but the pre-warning has alarmed.
    So yes staying out of a wreck or an er is worth the car payment.
    #11 rjparker, Jan 17, 2025
    eleison likes this.
