Help! 2012 Prius won't start... any ideas?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rukawa11, Aug 6, 2014.
  1. rukawa11
    rukawa11 Junior Member
    new york
    Hey guys, was wondering if you could help me. I went to my garage today and went to open the door... it didn't beep and unlock... let's try again...same results.
    Took the remote out and pressed the unlock button 4 to 5 times and no dice either. Ok what the heck? Took the key out of the remote and manually unlocked it, sat in the car pressed the brakes to turn the car on and the brakes were really hard to depress. Power button was a no go as well.
    The interior lights were on but really really dim. I am completely baffled, just drove the car 48 hours ago. The car is the 2012 model with about 11k miles. I do leave a dashcam plugged in that turns off automatically when the car is off and haven't had any problems with it for the 2 months I've had it. Thanks for any help and ideas before I jump it with my portable jump starter.
    #1 rukawa11, Aug 6, 2014
  2. JC91006
    16,479
    8,397
    In any other car, this would tell you the battery is dead. Same here in your prius
    49,429
    get a trickle charger, and charge the 12 volt battery overnight. did you leave the dome light on or a door/hatch not closed all the way?
  4. rukawa11
    new york
    Ah got it.
    Nope I didn't.
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    257
    Ocala, FL
    AND.....if charging the 12 V brings it back to life, you probably are due for a new battery.
    Along with that, the charging voltage needs to be checked.
    Loose or corroded battery cables are also a possibility.
  6. Mendel Leisk
    38,700
    Check the voltage of the battery with a digital multimeter.
  7. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    You need a new 12 volt battery.
  8. siuschef
    siuschef New Member
    Seattle, WA
    Which digital multimeter would you recommend? Thanks!
  9. Mendel Leisk
    38,700
    No preference really.
    I have a Milwaukee, but was not to impressed: left it face down for a few months and a corroding battery dripped all over its circuit board (replaced under warranty).
    Just see what’s available, check reviews, doesn’t need to be too expensive.
