HELP - 2014 Prius V - U0129 ???
Discussion in 'Prius v Technical Discussion' started by svldvc, May 10, 2022.
Tags:
  1. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Bought this car like this.
    Has U0129 codes.
    Screen for some reason doesn't show energy screen with battery or anything when engine running to charge HV battery.
    Also "Break" light is on,
    "Traction Control" light is on
    "power steering" light is on
    "ABS" light is on
    "Car !" light is on
    Please advice where to look for issue.
    I'm a DIY guy and usually do all service myself.
    Plz don't tell me to take it to a "stealership"
    52,376
    not at all, just get a copy of tech stream to read the codes properly, then grab the service manual at techinfo.toyota.com for troubleshooting
    svldvc likes this.
  3. ChapmanF
    18,534
    You don't necessarily have to go straight to techinfo.toyota.com for the manuals; there are other options you might like better if they're available in your neck of the woods. We have a wiki page that gathers a bunch of the options in one place.
    Toyota Service Information and Where To Find It | PriusChat
    svldvc likes this.
  4. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    **SOLUTION**
    I read about every post on this forum with that code.
    Boiled down to checking every fuse. All fuses by driver knee panel were good.
    When I got to the engine bay ones, I discovered that the very far left 7.5Amp fuse labeled as: "ABS MAIN NO. 2" was blown.
    Have no clue what, how and why it had blown.
    Replaced it and immediate as I did so, the break fluid pump (I'm assuming) did its typical pre-start up "whirling" sound that it does every time you step on the break paddle when the car is "off".
    I usually always listen for that sound when I get inside the car and press the break paddle before I hit the "Power/Start" botton. Don't know how I missed that....
    Welp, I'm glad it was a very simple fix.
    Hopefully it will help someone in the future.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    What app and adapter are you using? It seems that you have decent code scanning capabilties there. So far I my "favorite" (most capable on a Gen2) is the Autel Maxi AP200. I would like to research whatever it is that you are using.
  6. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    I wonder what blew the fuse. My v had over 300,000 on it and that never happened to me.
  7. Air_Boss
    Air_Boss Senior Member
    4,222
    1,188
    New Yawk
    Now you'll have to determine why that fuse failed, and monitor whether it fails again.
  8. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    I wonder if the trani Inverter water pump is going bad.
