Help... 2017 Prius electric water pump removal
Discussion in 'Gen 4 Prius Main Forum' started by 2017 Prius, Mar 23, 2020.
  1. 2017 Prius
    2017 Prius New Member
    Tacoma, WA
    I'm trying to replace a 2017 Prius electric water pump but it physically won't come out. What is the trick? Thank you for any help you can provide.
    amos likes this.
    49,371
    anyone?
  3. robsnyder20
    robsnyder20 Active Member
    374
    301
    SW Florida USA
    I doubt anyone on here have removed the water pump yet. The best advice is to talk with a local mechanic or get a subscription two days to the TIS technical toyota for complete teardown. I guess its not covered by warranty (over 60k perhaps) which is sad that yours failed so early.
    amos likes this.
  4. CooCooCaChoo
    CooCooCaChoo Senior Member
    899
    501
    Cow-lee-fornia
    2023 Prius
    amos likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Have you tried taking the passenger front wheel off?
    Usually you can access through the opening there.
    I swapped out our old 2010's water pump and did it from the top side. It was 5 fasteners.
    Don't forget you'll probably need some Form In Place Gasket (FIPG) material too.
    amos likes this.
  6. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    954
    720
    Boulder Hybids, Boulder, CO
    The trick is you need to support the engine from below with a jack then remove the top motor mount, lower then engine assembly approx 2" then pull the pump off the engine (5 bolts) and out from below.
    You don't need FIPG gasket material, new pump should come with an appropriate rubber gasket.
    For gen3's there is enough clearance to pull them out without lowering the engine.
    #6 3prongpaul, Mar 27, 2020
    Mylar, Tande, Mendel Leisk and 2 others like this.
  7. amos
    amos Active Member
    341
    281
    los angeles
    Could you tell us bout the symptoms you had that made you think replacement needed? How many miles on it. Hardly 3 yrs old.
    Marcius, Tande and Raytheeagle like this.
