Help! ABS code that won't go away!!!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Boognish, Jul 30, 2025 at 9:45 AM.
  1. Boognish
    Boognish New Member
    Yesterday
    usa
    Hello beautiful people and community:
    I have a 2013 Prius 5 with 200k miles. I bought this car with all the lights on the dash lit up like xmas tree. I had to replace the steering rack as soon as I bought the car, as it wouldn't drive straight. I have C1464 code for my front right ABS sensor. I verified on techstream that it is reading 0mph. I replaced the ABS sensor, still didn't fix it. I replaced the wheel bearing (thinking maybe tone ring issues) and still didn't fix it. I unplugged the connector from the ABS module, and verified that the wire is in good condition, and both front ABS sensors reading around 1.2-1.9 megaohms.
    I really don't know what else to replace. I know these cars have issues with ABS, but not exactly the module going bad. Of the more than 4 dozen cars i've had in my life, this is the first time I'm suspecting an ABS module just going bad, and not reading ABS sensor anymore.
    Is there anything else I can test here before just buying another ABS module and pump assembly? What is the best source for those things?
    Thank You, and be safe out there
  2. Tombukt2
    Tombukt2 Senior Member
    12,320
    2,177
    Durham NC
    The ABS modules two of them go out on this car all the time you can read hundreds of posts about just that .
  3. ChapmanF
    17,470
    If the only code you have is C1464 for a specific wheel sensor signal, have you followed the full troubleshooting procedure in the repair manual for that code?
    Toyota Service Information and Where To Find It | PriusChat
    There are probably more answers besides "replace the sensor" or "it has to be the ECU".
    There's a PDF of the 2010 manual floating around but doesn't have that code in it. It may be a code added in a later model year. Might have to go on TIS to read about it.
  4. Boognish
    Boognish New Member
    Yesterday
    usa
    is that just the gen 2, or gen3 also has same issue?
    I don't have the full repair manual, so... but really there isn't too much involved. I just find it crazy it would be the ABS module
  5. h1ph0panonymous
    240
    33
    Try replacing the pigtail even if it reads good, the terminal could be bad itself.
  6. Tombukt2
    12,320
    2,177
    Durham NC
    The gen3 has two pieces on firewall that separate the pieces. It's recommended to replace both on gen3 see bulletins. We won't worry about gen2
  7. ChapmanF
    17,470
    Yeah, seeing that the only trouble you have is for a single wheel sensor signal, and you have none of the codes associated with the way the module usually wears out, I would for now keep focusing on the troubleshooting steps for the code that you have.
    Even that code's troubleshooting could, possibly end up back at the module (once you're sure you have conclusively ruled out the sensor and all of the wiring), but that isn't common.
