Help asap, roaring engine sound after oil over fill?
Discussion in 'Gen 2 Prius Main Forum' started by Jcrew6311, Jan 13, 2022.
  1. Jcrew6311
    Jcrew6311 Junior Member
    31
    Mesa,az
    Help please asap! Prius showed signs of low oil but only at 2k mile interval (it's an 08 and I'm getting what I can out of it). anyway, I topped it off yesterday, probably more than I should have. Well this morning I go to drive and after 10 seconds it sounds like a motorcycle starting up and is getting increasingly louder. Honestly like a roaring sound. I stopped immediately, drained some oil, tried again, same thing. I'm not about to drive it today because it sounds like it could explode with me inside it! When I get home today I plan to do a full oil and filter change, but what could have caused this? Did I damage something?
  2. Tombukt2
    Tombukt2 Senior Member
    10,054
    1,734
    Durham NC
    I'd love to hear a sound bite of that when you say overfilled how far past the top dot or line on the dipstick were you quarter inch half inch a full inch would be a start I know over filling a two z z which has nothing to do with us here problems I didn't know the one nz which is our engine had this problem and you say you're just stringing along an 08 I've got an 09 that's pretty much imperfect condition it's the ugly gold with the terrible interior but I can't kill it I haven't had to do much nursing but a battery in it a few weeks ago but it was 20 years old
  3. alftoy
    alftoy Senior Member
    1,132
    510
    Saskatchewan, Canada
    Maybe you could look under the car and see if you still have a catalytic converter.
    If you are still having other issues with your Prius give Steve a call in Phoenix, he can do mobile services, maybe a tuneup for reasonable price.
    Services — PHOENIX HYBRID BATTERIES
    #3 alftoy, Jan 13, 2022
    edthefox5, rogerthat, gdanner and 2 others like this.
  4. MickyMatter
    MickyMatter Active Member
    260
    167
    Germany
    Theoretical: Overfilling the engine oil leads to a too high oil level. Then the crankshaft can reach the oil surface. The eccentric cranks hit the oil at high speed, like e.g. a man jumping into water from a height of 100 meters (or yards). This can cause physical damage to the crankshaft, connecting rods, pistons and/or their bearings.
    I wonder if this is what happened. IDK. Hopefully not! Good luck!
    FP4 ?
  5. OC63RAG
    OC63RAG Member
    94
    42
    What were the "signs of low oil" and where was the oil on the dipstick after filling it?
  6. Jcrew6311
    31
    Mesa,az
    it was up wayyy past, probably a good 8-10 inches. I drained it out but I'm doing a whole new oil drain, change, and new oil filter too tonight. Hopefully this fixes it?
  7. OC63RAG
    OC63RAG Member
    94
    42
    How much did you add to it?
  8. alftoy
    1,132
    510
    Does it sound like this?
    gdanner likes this.
  9. Mendel Leisk
    39,015
    How long's the dipstick, lol.
  10. gdanner
    gdanner Member
    86
    39
    Central Illinois
    A few days ago I got into my Prius and was rewarded with very very loud exhaust noise. As in "no muffler or pipes at all."
    A quick look underneath revealed both catalytic converters were GONE. The wires for the O2 sensor were left dangling where they had been torn off. The 2 saw cuts where the cat had been cut out were surprisingly clean and square. These thieves not only had brand new saw blades but they also demonstrated the skill to make clean square cuts in a hurry
    When I reported this to my local PD they said "We are chasing the catalytic converter thieves right now but we haven't caught up with them yet." They had already received reports of more than 20 catalytic converter thefts during the past 3 days. The town I live in (east central Ilinois) is not a "big city" by any means. But these cat thieves are working everywhere these days. It isn't just a "Los Angeles thing" now.
    FYI, my local muffler/exhaust system shop recommends the aftermarket 2Gen Prius Cat sold by Rock Auto under the "Walker" brand. It is about $330. I'm ordering one today and also a new O2 sensor.
    I've read that cat thieves know how to ID a genuine OEM Prius cat vs. an aftermarket cat. They won't steal aftermarket units because these aren't worth anything to the people they sell to. Only original Toyota OEM cats are valuable enough to merit stealing them. So I'm hoping replacement with the aftermarket unit will save me from future cat thefts.
  11. Jcrew6311
    31
    Mesa,az
    OMG it sounds EXACTLY like this!!
  12. Jcrew6311
    31
    Mesa,az
    Would the car make this sound if the oil was severely over filled too, or is this sound specific to the catalytic converter?
    OC63RAG likes this.
  13. OC63RAG
    OC63RAG Member
    94
    42
    It sure sounds like your cat was stolen. Take a look underneath and you'll find out for sure.
  14. Jcrew6311
    31
    Mesa,az
    Got a part number for that?
  15. Jcrew6311
    31
    Mesa,az
    So my neighbor found this under the car just a bit ago when looking. He said he thought it was from the exhaust. Any ideas?
  16. alftoy
    1,132
    510
    Bolt and spring for catalytic converter. Attaches the cat converter to the exhaust manifold.
  17. Jcrew6311
    31
    Mesa,az
    So do I just need to screw it back in?
  18. Mendel Leisk
    39,015
    ^ This.
  19. Jcrew6311
    31
    Mesa,az
    My neighbor said CC is still there. Said O2 sensor is loose and exhaust is loose.
  20. pasadena_commut
    pasadena_commut Senior Member
    1,630
    489
    Southern California
    Sounds like the thieves were interrupted and left your cat partially disconnected. Because damaged O2 sensor wires can short the computer it would be best not to turn this back on. Have it towed to a reliable Toyota mechanic for repairs. Definitely not whichever shop messed up the oil fill! Most likely they can put it back together, perhaps with a bit of welding. While there, have a cat shield installed.
    Mendel Leisk and OC63RAG like this.
