Help! avic-z110bt and rear view camera install
Discussion in 'Gen 3 Prius Audio and Electronics' started by netgo, Apr 5, 2010.
  1. netgo
    netgo New Member
    25
    US
    I am installing rear view camera and avic-z110bt.
    avic-z110bt has a function which enables rear view in map mode. So you can watch rear view during driving in map mode.
    My camera has RCA video out and 12V power input.
    Instruction manual says connect power to back light lead. But in this case, how rear view in map mode works?
    Should I connect camera power to ACC power instead?
    If I connect camera power to back light lead, camera will be only on when back light is on.
    Any thought? Thank you
  2. austingreen
    austingreen Senior Member
    13,533
    4,062
    Austin, TX, USA
    I connected it to acc. It works fine.
    The camera I have draws 100ma.
  3. netgo
    netgo New Member
    25
    US
    If I connect it to ACC, will it shorten camera life? Or will it be ok?
    My camera spec says power comsumption is no more than 300mA
  4. Rebound
    Rebound Senior Member
    3,961
    2,609
    Portland, OR
    300mA is nothing. Don't sweat it. A phone charger in the cigarette lighter draws 500mA.
  5. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    You can also connect the power to the blue (I believe) power wire to the rear wiper. It is on when the car is on - but very easy to get at...
  6. Byhre
    Byhre New Member
    Newyork
    I just got a rear view camera, but did meet the same problem for installation, I did cost a lot of time. Did try to connect the power cable with the same color, still unworkable. :eek:
