Help Battery FAILURE!
Discussion in 'Newbie Forum' started by FormerPriusLover, Jul 8, 2011.
  1. FormerPriusLover
    FormerPriusLover New Member
    United States
    ‎135,000 mile 2006 Prius and my core batteries ($3,500) need to be replaced, anyone recourse from Toyota for a similar situation?
    THANKS FOR YOUR HELP!
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    where at in the U.S. are you?...
    a lot of people are going to start asking you why you think it needs to be replaced... there's a lot of info out there.
    so.. i'll start with: why? did the dealer tell you this? if the car is throwing codes, what are the codes.
    are you still using the original 12v battery? if so, it's dead, get a new one... the car may not even start since it's old.
    more info?...
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    If you live in a state that had adopted CARB (California) emissions, then you may be covered to 150,000 miles. That is your only recourse.
    I would not recommend paying $3500+ for new batteries. You have options. If you will provide your location, we can give you a better idea of the alternatives.
  4. direstraits71
    direstraits71 Member
    367
    64
    Central Coast California
    Considering a new battery from Toyota is <$2000, (see link below) $1500 for installation which takes only a few hours at the most is pretty darn high. I'd be shopping if I were you if you can't get Toyota to help you out.
    Champion ToyotaWorld
  5. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Dealer will charge MSRP, $2588, plus 3-6 hours labor. Some also insist on a new HV battery ECU. Nowhere in America will a dealer do this for less than $3000, unless it is a goodwill gesture from them and/or Toyota Motor Corporation.
  6. JimboPalmer
    12,470
    6,870
    Greenwood MS USA
  7. direstraits71
    367
    64
    I agree if you let a stealership do the replacement. Hefty profit for them for sure.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    It is unlikely it even needs to be done in the first place, so perhaps you should post the symptoms.
    And if it does need to be replaced, buy a ReInvolt battery for $1500 and install it in an hour.
  9. kammssss
    kammssss Member
    287
    86
    SoCal
    I am from the Los Angeles county area. I'll replace your HV battery for $300. I can't believe the stealership would charge that much. Email me directly.
  10. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    NOW, There is a deal, the OPs probably on the East Coast.
  11. kammssss
    kammssss Member
    287
    86
    SoCal
    I know. I should have a part-time mobile Prius garage or something. No offense to Prius owners, but most of us are a sucker for the stealership, especially here in SoCal where the stealerships' hourly labor rate is almost $300 (I saw my stealerships' labor rate at $289 Wth!).
  12. jdenenberg
    jdenenberg EE Professor
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    My CT Toyota dealer installed a ReInVolt battery in my 2004 Prius for <$400. ReInVolt does the install for <$300 in NC. So there are East Coast solutions as well.
    JeffD
  13. phoebeisis
    phoebeisis Member
    139
    Big aside-Yikes- $289 shop rate?
    How much does the mechanic actually make?
    Piecework fixed amount per job or hourly I wonder?
    Thanks
    Charlie
  14. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Man, this is why I love this forum. :peace:
  15. andyman68
    andyman68 Member
    131
    Columbia Missouri
    Saturday I had to drive about 18 miles on a short trip. When I left home I thought the car seemed a bit sluggish but didn't think too much of it. About halfway there a bunch of lights on the dash come on and the top of the display in the console screen had a pretty red picture of a car and the top was blank. The lights on the dash were VSC, something orange with an exclamation point, an outline of a car, and a big red triangle with an exclamation point. The car was going 70 mph and nothing really seemed too out of the ordinary other than a little sluggish.
    I made it to my destination just fine and noticed the hybrid battery was completely full green and I was running the AC. On the way back the lights were still on and I noticed the sluggishness on the Interstate even though I could get up to 70 mph but it just didn't seem to have the normal power.
    I checked the hybrid battery on the display and it was in the purple zone down to the last bar. Not out of the ordinary on a hot day but out of the ordinary when going 70 mph plus it was fully green on the trip there. I shut off the air conditioner and got it to charge a bit and get to 3 blue bars but then it it went back to two purple bars. It was about 85F outside and the cooling fan in the back seat was running constantly.
    Once I got into town and off the Interstate I was actually near the dealer. It went down to 1 purple bar so I pulled in and checked it in since I wasn't sure I would make it all the way home. The service guy said often several of the lights come on when there are other issues.
    This car is a 2006 with 116K. Today they call and say it is hybrid battery failure which I find hard to believe. They want about $3K to replace. Are there any other options other than trading in the car?
  16. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    get a battery from XVipers. They are okay if you deal with them in person. If I recall correctly, they will even do the installation for you. XVIPERS INC
  17. jdenenberg
    3,859
    1,858
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You have several lower cost alternatives. The best two are:
    1. Plug In Hybrid Electric Vehicle PHEV (AutoBeYours) buys wrecked Prii and produces reliable salvaged Prii out of them. They are in Scottsburg IN (about 7 hours drive from you) and will fix your Prius at a low cost using a salvaged HV battery. There is a low cost motel less than a mile from his garage where I stayed when I had Steve (the owner) fix my Prius for $40 (A cable connector came loose).
    2. Remanufactured Hybrid Vehicle Battery Packs (ReInVolt) produces reliable rebuilt HV Batteries (I have one in my 2004 Prius). They cost about $2000 installed, but you will need to find an installer at a drivable distance from you.
    JeffD
  18. Flying White Dutchman
    4,374
    313
    TS stayed at this one post.... maybe a troll trying to put the prius down?
    the response is probably not what h expected:D:D
