Help! Battery only charging downhill and braking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rheannonr, Sep 19, 2014.
  1. rheannonr
    rheannonr Junior Member
    Paso Robles
    Hello. Right now my husband and I are driving from San Luis Obispo Ca to LA and back in a day. We noticed right before the grape vine on the I5 that the engine was really working, even on flat ground. Looked at the battery and it was purple. We have been driving for about 2 hours averaging about 70mph on mostly flat land. The battery finally charged itself on the big downhill of the grapevine (I5) but we're noticing we're running right through it again unless we start to break more. So, it's not getting any recharge during driving, just breaking. Can it be the generator? Does anyone know what causes this?
    Thank you!
    49,725
    welcome to priuschat, how many miles on her? have you done all the recalls? could be your hybrid battery, maybe the inverter, you should get to the dealer and see if there are any codes.
    rheannonr likes this.
  3. JC91006
    16,496
    8,406
    I suspect it's the driving terrain you are going through. Since you are already on your trip, there's not much you can do. When you go home, see if everything goes back to normal. If it does, then it was just the terrain you were traveling through.
    You should also check the oil level in your car, just to make sure it's not running low. This does not have anything to do with the charging issue you are mentioning...
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Are there any air vents for the HV battery in the V? On my Prius there's on on the back seat. If it gets blocked (by a coat or a person etc) then the battery can exhibit similar symptoms to yours.
    So have you inadvertently blocked this vent? by a passenger, a coat, a dog, a box etc?
  5. Fifine
    Fifine Member
    106
    So Cal
    Passenger side backseat, next to door.
  6. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    1. Did you start the highway trip with a low (2-3 bars) battery? I find it odd that it isn't charging even on the highway, because that's almost all my prius does on the interstate/highway.
    2. What kinda mpg have you been seeing lately?
    3. What is your energy monitor doing while cruising?
    Best of luck! Keep us updated
