HELP: broken throttle body stud
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by waldox, Sep 30, 2021.
  1. waldox
    waldox Junior Member
    69
    toronto
    i was cleaning my intake manifold egr ports and installing an oil catch can
    upon reinstalling the rusty bolts and nuts one of the of the intake manifold studs (upper right stud, using 15 ftlbs of torque spec'ed)
    seems like its running fine no leaks. any way to replace the stud or is it welded onto throttle body?
    should i just leave it like that if there are no leaks? (normal fuel trims)
  2. Mendel Leisk
    40,582
    Seems like something missing above; I've added/revised the red. Is that what you meant?
    Regarding the torque values:
    For the two bolts and two nuts holding down the throttle body, the torque is 7 foot/pounds. The studs are 44 inch/pounds (a shade under 4 foot/pounds). I'd acquire a 1/4" drive torque wrench if you don't have.
    The studs screw into thread inserts bonded into the plastic of the intake manifold. Typically they're installed/removed with an E6 Torx socket. Torque the aforementioned 44 inch/pounds.
    Repair Manual excerpt (showing intake manifold and torque values) attached:
  3. ChapmanF
    17,343
    Goodness gracious, are you sure? Those throttle body studs and bolts don't look nearly that big.
    My manual says seven foot pounds (ten newton meters).
    If you take the throttle body back off, if you're lucky, some of that stud is still poking up, you can grab it with vise grips and unscrew it, and replace it with a new one (or just use a bolt from the top there; I've never been sure why they did the two bolts / two studs thing).
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I must be having eye problems. It looks to me like there's a nut on that stud...........maybe it's just the piece of stud that normally protrudes a bit, that snapped off? Were the studs/nuts removed as an assembly and installed using the torx on the top of the stud? or were the nuts removed using a deep socket, leaving the stud installed in the manifold??
    If it's just the top portion of the stud that broke off, I'd leave it alone till next time..
  5. Mendel Leisk
    40,582
    Thing is too, if you remove the studs, then you can get "creative" reinstalling them.Common sense says to install them diagnonally opposite each other, and does it matter which direction diagonal. Give your head a shake: doesn't matter.
  6. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Also, if it is just the top portion of the stud that broke off, it's super simple to remove at next opportunity if desired. Just remove the nuts and the bolts, remove the throttle body and double nut the broken stud. Then all you have to do is use a wrench on the inner nut to back the stud out.
  7. OptimusPriustus
    OptimusPriustus Active Member
    328
    137
    Finland
    Probably speeds up assembly a little. One can just drop the body and it aligns perfectly by itself and gasket get no massage. They have lot of little things everywhere. Like those marker dots seen in the picture. We’re talking about one of the most efficient car manufacturers out there, if not the most efficient
    #7 OptimusPriustus, Oct 21, 2021
