Help calm my nerves with this issue
Discussion in 'Prius c Fuel Economy' started by ageless, Oct 5, 2012.
  1. ageless
    ageless New Member
    38
    As everyone else does here I am driving my PC3 like I'm driving Ms Daisy in order to minimize fuel consumption and jack up those MPG's. I could absolutely run this car in a ditch when I begin to back off the pedal while headed downhill(a steep long one, mind you) and this son of a *_(*%$# slows from 65 to 60. I have NEVER owned or heard of a car that slows down when going downhill!!! I even put the car in neutral and guess what??? IT SLOWS DOWN!!!!
    Wth is worng with this car? Is everyone else experiencing this?
  2. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    I can only assume that it's physics...that the hill must just not be steep enough to maintain the momentum you need to stay at that speed. It is a relatively fast speed. But not knowing the hill myself it's hard to say. I certainly haven't noticed the car slowing down while going downhill, but I haven't been down any that fast.
  3. PriusCamper
    PriusCamper Senior Member
    11,104
    4,518
    Pacific Northwest, USA
    Jack up each wheel and see how well it spins... Also maybe tire alignment... Downhill coasting in neutral should be significantly less resistant to the downhill when the car is in drive or in B mode...
  4. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    While this cars coefficient of drag is low for a hatchback your Previous car could of been lower. Also this car is pretty heavy for its size but your old one may of been heavier.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Make sure parking brake is not engaged?
  6. Revan86
    286
    84
    Lol. Had a ex that did that lol.
    God I hate her
  7. ageless
    ageless New Member
    38
    checked, it's fine
  8. ageless
    ageless New Member
    38
    former car was an 08 avalanche
  9. ageless
    ageless New Member
    38
    I'm gonna video the hill and the dash next time I go down it, it is insane.
  10. ageless
    ageless New Member
    38
    the car only has 1000 miles on it, alignment should be perfect. I have pondered what the issue might be. Wheel bearing? axle?
  11. John H
    John H Senior Member
    2,208
    558
    maybe post the route, or at least the downhill section, from google maps.
  12. Forza4
    Forza4 New Member
    It could be hand brake adjustment that is too tight or rear brake shoes adjusted to tight in the drum or defective front caliper that keep too much pressure on the disk or defective bearing. Since you put it in neutral and it did the same, it's not transmission or motor related. One thing for sure, it's not normal ! How is your fuel MPG ? Is your tires under inflated ?
    PriusCamper likes this.
  13. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Regen braking can cause the car to slow down on very mile hills. You could try coasting (gliding) although neutral would work the same. Are you sure you were in neutral?
  14. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    Mine speeds up going down even small hills as long as I keep a light foot pressure to keep regen off. Either the hill is an optical illusion (don't laugh - it can be that way) or something is wrong with your car.
    KK6PD and RocMills like this.
  15. Sagitar
    Sagitar Junior Member
    59
    Ampthill
    Did you have cruise control set? Mine will attempt to maintain the set cruise control speed when going down hills.
    Mendel Leisk and KK6PD like this.
  16. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    Another thought, make sure you are in D not B!
  17. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    Ageless, I agree with others... this is something wrong with your car or what you are doing. My C2 will eventually slow down when I pop into neutral on a flat stretch of road, and it will even slowly speed up a mile or two if there is the slightest downward incline. Slowing down in the situations you described is not normal.
  18. photogrl13
    photogrl13 Member
    115
    47
    59
    Columbus, Ohio
    An Avalanche is a lot heavier than a C, therefore it has more momentum and reacts differently to hills. In particular, it would accelerate more rapidly while going downhill than the lighter C. On most of the hills I drive, I don't decelerate while in D. If I move to N I'm pretty sure I would accelerate, but not very quickly. If it is a steep hill and you aren't accelerating slightly in N then I would assume something is amiss.
    Things to check if you are worried: Tire pressure, brakes (perhaps they rub), oil clarity, fuel type, overall engine tune-up.
  19. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I do not think a Prius should slow down going downhill in Neutral, but depending on the grade, it could slow down with the transmission in Drive.
    If it slows down in Neutral, you should take it into the dealer.
    RocMills likes this.
  20. fuzzy1
    10,170
    It depends on the combination of speed and slope. I don't expect my liftback to maintain 65 mph when rolling in Neutral down a slope of just 1 or 2%, it is going to need something like 3%. There is still a lot of air drag at that speed.
