Help, can't seem to find answer
Discussion in 'Prime Technical Discussion' started by Rafael Aguirre, Apr 30, 2020.
  1. Rafael Aguirre
    Rafael Aguirre New Member
    Pomona
    2020 Prius Prime
    so, 2020 Prime, just had windows tinted, and I noticed the lights above brake lights are still on.
    After a bit a long beep from the car.
    Is it "CHRISTINA" ...I UNPLUG battery and see as to what happens and now it say key inside but key is not inside
    49,492
    check the 12v health, sometimes the tinters leave the doors open (dome lights) and drain the battery.
  3. Mendel Leisk
    38,727
    They've also been known to short out wiring: they spritz a lot of soapy water on the interior glass. They did the back window I'd assume.
  4. mistermojorizin
    mistermojorizin Active Member
    310
    136
    usa
    2019 Prius Prime
    i've read threads about lights staying on after tinting. it goes away after a while as the water dries.
