Help! Car turns on but shuts off after a few seconds + check hybrid system
Discussion in 'Gen 3 Prius Technical Discussion' started by Metaleckz, Sep 20, 2020.
  1. Metaleckz
    Metaleckz Junior Member
    23
    San Francisco
    Hello. I need your guys help
    I have a 2010 prius with 180k miles
    The inverter gave out on me 2 weeks ago. So i replaced that and all is well. After 4 days, my car broke on me again and it says the same “check hybrid system” i thought it was the inverter but when i ran the code. P3191, P3190 and P0A0F popped up. So its not the inverter and its something else. Now when i turn it on, the engine turns on but it would shut off after a few seconds. Do you guys know what could it be?
    edit: sorry. Its P3191 and P3190
    #1 Metaleckz, Sep 20, 2020
  2. RRxing
    RRxing Senior Member
    2,518
    1,790
    NEPA
    P1391 and P3090 don't appear to be valid codes in my Digital Trouble Codes (DTC) list. Here's what I see for P0A0F (not much help, I'll admit):
  3. ChapmanF
    15,100
    I would guess typos for P3190 and P3191. Important to type those pesky codes correctly in forum posts.
  4. RRxing
    2,518
    1,790
    NEPA
    If so, then...
    Screen Shot 2020-09-20 at 7.42.30 PM.png Screen Shot 2020-09-20 at 7.42.42 PM.png
  5. Elektroingenieur
    2,515
    3,253
    Three Touring
    The combination of diagnostic trouble codes (DTCs) P0A0F with P3190 and P3191 (assuming @ChapmanF's theory is correct) is mentioned in Toyota bulletin T-SB-0041-15, “MIL ‘ON’ DTC P0A0F, P3190, P3191, P0171 Due to Purge VSV Vacuum Line Separation” (PDF), issued June 30, 2015. The inspection of the hose and vacuum line in step 1, page 5, determines whether the repair procedure in the bulletin applies. If not, the Repair Manual (more info) has detailed troubleshooting procedures.
  6. Metaleckz
    23
    San Francisco
    I wish it was that one but both hoses are intact.
    T.Mehmood Khokhar likes this.
