Help: Car won't start. Serious electrical issue or minor?
Discussion in 'Gen 2 Prius Technical Discussion' started by thebardksu, Jan 6, 2011.
  1. thebardksu
    thebardksu Junior Member
    Denver CO
    Hi all. I will describe the situation as it happened and let you help me figure out what is going on.
    I was out of town for about a week. I drive a 2008 Prius with about 35k miles and no previous issues. I get back tonight and go to open the door with keyless entry. Nothing, doors wont open. I hadn't replaced the batteries in the remote since I bought it, so I figured it was just that. I use the key to manually open the doors. I then go to start the car. Nothing. No lights, no noises, literally nothing happens. I figure, perhaps I left a light on while I was away and the 12V battery is drained. It is quite the rare thing, but it has happened a few times in the past. Usually I would catch it the next day and be ok, so maybe a light was on for a week and that did it.
    So at this point I assume it's just a dead 12 V battery. I ask my friend to give me a jump. We open the hood, connect up the jumper cables in this order : + Prius, + and - to his battery, then - to the Prius frame. Quite a few sparks fly, which seemed like more than what I was used to seeing, but it doesn't seem too outrageous. I try to start the car and nothing happens. My friend then tells me he accidentally hooked up the jumper cables backwards. (I know now this is bad, and may be the source of the problem but please hear the rest of the story to get a complete picture of what's going on).
    So we swap them on his battery and try again. I put my foot on the break and push the power button. His car is still running in the background. The power button LED then turns green, and that is it. No noise or anything else. I then (while keeping my foot on the break still), push the power button again. This time the power button LED turns orange, the parking break P LED turns on green and the check engine light on the dash turns on. Also I think the car also makes the normal humming sound we are used to hearing when it turns on. No other lights are on at this point. The main display doesn't come on, nor does the interior lights work, or anything else for that matter. The only thing functioning from inside are those 3 lights. I turn the car off and we just figure it needs more time to charge. So we give it a few more minutes of charging and still the same thing. We notice a strange thing. We hear a clicking sound coming from the fuse box area of the car. Every 5 seconds or so, it sounds like a relay clicks, and then clicks off after 2 seconds or so, and this continues on. My friends engine sounds as if during those two seconds like it is sending current to my car (lower engine rpm). So it sounds as if the relay sends current somewhere for a few seconds and then no current goes to my car, 5 seconds later it sends current to my car then 2 seconds later no current, etc. This goes on continuously and we are not sure why.
    We figure maybe a fuse is blown. My friend checks the fuses we think to check but can't seems to find anything wrong there. We then think maybe the power needs to be disconnected to the electronics to allow capacitors and what not to discharge. So we disconnect the lug from the jumping terminal (the one we connected the + jumper cable under the hood) for about 10 minutes. We reconnect the lug back 10 minutes later and try again. Same things with the lights and buttons pushing as before. The only difference this time is you can get these lights to turn on without having the jumper cables connected (as if some of the battery was charged).
    Next we figure, maybe we just need to hook directly to the 12V battery in the "trunk". So we connect to that. Now, instead of having the relay tripping every few seconds we don't hear the relay tripping at all. And the engine rmps are operating constantly as if it is consistently drawing current (constantly lower rmp sounds). So that is different this time than when we connected to the post under the hood. So we continue running the car at high rmps for a few minutes and try again. Still the exact same thing with the lights.
    Also during these tests the break pedal seems to put pressure on itself when you hit the power button a second time and the lights turn on. (This is just a detail to include, I'm not sure if there is anything useful to gain from knowing this).
    Anyway, I know the problem is most likely that everything was fine until my friend accidentally hooked his end of the jumper cables to his battery. But in the event that there is something else I should check, that would be greatly appreciate before I have it towed to the Toyota dealership here.
    Thanks in advance for any help.
    P.S. and FYI, I have a bachelors and masters in electrical engineering so feel free to be as technical as you feel necessary with the electrical stuff. As far as car specific technology goes I am not quite as proficient with and would like the standard car dummy terms and explanation :).
  2. ggcc
    ggcc Member
    132
    Bay Area, CA
    2014 Prius Plug-in
    Sorry to hear this. I think your car is still under warranty (3Y/36K).
    This thread below might help (not a big problem).
    http://priuschat.com/forums/gen-ii-...8502-12v-battery-replaced-wrong-polarity.html
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    But not so your friend apparently. :(
    It could have done a lot of damage. I think in other cases where people have done this they have blown the inverter.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    If you are really lucky it will be a blown fuse. More commonly reverse jumping will fry the inverter or some of the ECUs. Repair costs are usually four digits, I'm sorry to say.
    Tom
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    I hope this story has a happy ending, either a blown fuse or covered by warranty. If it doesn't, you should know that Adopt-a-Part is right in your backyard and quite possibly has everything that you need in their collection of Prius salvage parts in order to get your car running again. There is also a hybrid shop in Denver to help on the diagnosis/install side, but I can't remember the name. From what I can tell, the only way the the inverter, computers, etc. fail in normal use is a reverse polarity jump, so just about any wreck would have the replacement parts that you need.
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Yea,
    I second what gbee42 says. Its unfortunate that the guy with the two electrical engineering degrees was not the guy hooking up the cables.
    You are going to need become friends with Steve at autobeyours.com real quick...
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    IF.....You have not been to the dealer, yet. When you go admit nothing. The car just failed, in street/ garage. NOTHING about jumping the battery!!!! The car looks like it may still be in warranty. There are also a few things that you can do before going to dealer. Use a DVM and measure the 12V, take the battery out and charge it on a bench, this will also be the equal of rebooting the system ( when reconnected ) If you do not remove at least the neg bat lead, it will not reboot. If you actually get the engine running, keep it in ready mode with engine running periodically this will rejuvinate the 12V and the HV batteries. Leave for several hours. Run NO accesories. Also when in ready mode read the 12V at either location, it should read about 14V. I believe this indicates a healthy inverter also. I may be wrong on this......hopefully others will chime in on this. Meanwhile read all posts on the 12V, Inverter and DC/DC converter. In Search
  8. JB84
    JB84 New Member
    Tucson
  9. bisco
    51,103
  10. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    :rolleyes:.
