HELP: CEL P0A80 for 18+ months!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MJ50, Aug 18, 2019.
  1. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    i've had P0A80 come on for last 18 months.
    when CEL came on, it never went to limp mode.
    checked block voltages with torque app every time and all were normal.
    last week, opened battery pack and measured each cell.
    7.87
    7.85
    7.84
    7.83
    7.83
    7.82
    7.82
    7.79
    7.80
    7.80
    7.81
    7.81
    7.81
    7.80
    7.81
    7.80
    7.81
    7.81
    7.81
    7.81
    7.81
    7.81
    7.82
    7.81
    7.82
    7.83
    7.85
    7.86
    outer cells are balanced and inner cells are balanced.
    is it possibly throwing code because gap between the two are high?
    if so, do i need to replace entire pack??
  2. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    The code can come on for multiple reasons ;).
    Getting a subcode will help with the next steps (y).
    m.wynn likes this.
  3. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    it didn't throw any other code for last 18 months... :(
  4. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    I would say you should balance them all close to same voltage
  5. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    And you’re reading the codes with Techstream?
  6. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    techstream and torque
    Raytheeagle likes this.
  7. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    that won't be easy diy... :(
  8. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    So no snowflake icon was present for further data?
  9. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    the blue icon in front of P0A80?
  10. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Yes;).
    Click on that and an INF code will be available(y).
  11. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    oh, didn't know that...
    will try it in few days when CEL comes on again... :D
  12. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    looks like i need to replace cells in block #4 and #5?
  13. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    That’s where I’d start;).
    But your whole pack isn’t looking that great:cool:.
    Measure all of the modules voltages and see where each one is at. In blocks 4 and 5 one cell is out in 2 of the 4 modules that compose those blocks.
    If you do this yourself, you’ll want to balance the modules, otherwise the repair you do will be something you’ll get very familiar with:(.
    The longer you drive without dealing with the problem the system is telling you about, the worse the other cells get as they are “making up” for the bad ones.
    Good luck and keep us posted (y).
    m.wynn likes this.
  14. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
    Some ideas...
    Use the torque app to record the cell block data while driving.
    Then export that csv data file to Google sheets and make a graph.
    Or use Techstream to record the values and make a graph. This may help you see what is going live.
    Carefully inspect all wiring connections, including ring terminals. Especially the ones hidden underneath other connections.
    Inspect for corrosion on the orange connector that goes into the computer in the hybrid battery, as well as pins on that computer.
    You could also spend time load testing all the modules and then rebalancing the pack afterwards
    m.wynn and Raytheeagle like this.
  15. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    update. replaced battery pack and no more CEL.
  16. Peter123
    Peter123 Active Member
    132
    128
    Where did you get the battery pack? Is it new cells or a rebuild?
  17. MJ50
    MJ50 Junior Member
    69
    S. Pasadena, CA
    ace hybrid. it's rebuild but comes with 2yr warranty...
  18. bisco
    52,350
    congrats, all the best!(y)
    MJ50 likes this.
