Help - cracked engine head OMG I think I just ruined my wife's car!
Discussion in 'Gen 2 Prius Main Forum' started by Drclaw, Apr 13, 2018.
  1. Drclaw
    Drclaw New Member
    Ma
    Hi everyone, first time poster here. I've been browsing the forums in anticipation of changing my wife's PCV valve on her 2007 Toyota Prius. I was I in the process of using a crows foot to remove the PCV valve. When I realized that the top of the engine block broke! See picture. Am I screwed?!?!!!!
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,916
    Columbia, SC
    You've put a bit of a hole in the valve cover. Since you likely don't have an extra valve cover laying around, what I would do, based only on the photo, is carefully fish out the broken piece, (assuming no other pieces fell in) clean the area very well, fabricate a small piece of metal/tin/whatever that would cover the hole. Mix up some JB Weld and us the previously made patch to cover the hole. Just don't go crazy with the JBW. Don't want any dripping into the engine. Start looking for a replacement valve cover. Should be plenty out there on ebay/etc.
  3. Drclaw
    Drclaw New Member
    Ma
    Already fished the broken pieces out . Just cut a couple metal stopss from a jar lid . Cleaned area with brake cleaner and rag . Gonna k
    Jb weld
  4. Drclaw
    Drclaw New Member
    Ma
    Well it's on there.
    Aaron Vitolins likes this.
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    EXACTLY! Just "glue" it back in place. You will NEED to clean the area with brake-parts cleaner and a rag first, to get the oil/grime residue off first, but this is not a real problem, unless the piece drops in. If that happens, you will have to remove the cover, fish out the broken piece and might just as well replace the cover and gasket.
  6. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    I haven't used JB weld, but you might want to check that whatever adhesive you use is intended to do metal-to-metal bonds, and is certified to withstand the temperatures reached by the engine block. I would also consider using Permatex Form-A-Gasket (the hardening, non-flexible version) as it is designed to work between clean metal surfaces and hold at the normal operating temps of an ICE. I totally agree that finding the piece , cleaning it, and prepping the surface is key to having a successful bond of the broken piece back onto the valve cover.
  7. Mendel Leisk
    38,727
    This has been reported at least twice before that I can recall. The peril of using anything other than a (deep) socket to bust it loose, and yeah: JB Weld has worked before, it's just the valve cover. It's an aluminum casting? Stamped steel would maybe have been better, and/or a bit more clearance.
    m.wynn likes this.
  8. Mendel Leisk
    38,727
    Made a little sketch:
  9. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Most of the time JB weld is not going to hold long term. So source a used valve cover and new valve cover gasket while it's still holding.
    GOOD LUCK
  10. 05PreeUs
    1,097
    563
    MSP
    Open-end wrenches make one H#LL of a powerful lever! You bust locks with them! :eek:
  11. Drclaw
    Drclaw New Member
    Ma
    Well I patched it up and put everything back together and car is running fine so far. I used layers of the metal strips i cut from flat jar lids. Didn't really go anywhere though. Tomorrow I'll put some miles on it.
    I found valve covers on eBay for like $45 shipped .Doesn't look too bad to install. 6 bolts? Might need to remove windshield wiper covers to get it .I'll change the gasket there too? What do u guys recommend?
    Thanks everyone
    #11 Drclaw, Apr 13, 2018
    douglasjre, Robert Holt and bisco like this.
  12. TMR-JWAP
    6,229
    5,916
    Columbia, SC
    Oh...my....god....
    Blasphemy!!!! How dare you doubt the power of JBW!!!!!!! Unforgiveable......
    Of course, now that I said that, it will probably fall off tomorrow morning....
    Aaron Vitolins and m.wynn like this.
  13. fotomoto
    5,602
    3,779
    So. Texas
    LOL!
    Yeah, it doesn't bond well with surfaces impregnated with oil or solvents unless thoroughly, thoroughly cleaned on both sides. In the motorcycle world, it's good band-aid for cracked or holed engine side cases/covers to get one home but not a permanent solution.
  14. Mendel Leisk
    38,727
    edthefox5 likes this.
  15. Mendel Leisk
    38,727
    You could get away with using a wrench, if you kept it up near vertical, but you're playing with fire, lol.
  16. tada
    tada Member
    73
    77
    Tucson, AZ
    2002 Prius
  17. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Someone has some spare time on their hands:whistle:.
    I can tell what you used to do in a working career;).
    Well drawn example(y).
    qettyz, Prodigyplace, bisco and 4 others like this.
  18. Mendel Leisk
    38,727
    AutoCAD sells for god knows what these days, 2~3 grand. And a lot of the big engineering companies have shifted to other programs, more conducive to 3D modelling. I would check on their model, then play around with my acad, splishsplash in the shallow end. Enjoyed it. (y)
    Merkey and Raytheeagle like this.
  19. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Once had a CB400A parked between two vehicles, someone with a tow hitch backed into it and left a broken 'H' shape in the engine cover before eventually knocking it over.
    Took the cover off and cleaned the surface (don't remember prepping it with sandpaper or wire brush, but might've), taped/plugged up the backside, made a small berm around the broken H (hole) on the front side, mixed up the JB, filled the hole, let it set up for a bit, then stuck it under a spot lamp for a quicker cure time (didn't want to wait for hours/overnight).
    A quick and easy fix that lasted for years, though there was some sweating via the 'pores' in the JB patch (never enough to form a drop), but it did make it look lightly sooted over a period of time.
    fotomoto and Raytheeagle like this.
  20. Patrick Wong
    18,200
    6,474
    Yes, you need to change the valve cover gasket. Also, you need a small amount of Toyota black FIPG (form in place gasket) which is used to seal two places where the oil pump/front engine cover contacts the cylinder head and the valve cover.
    Mendel Leisk and SFO like this.
