Help! Dealer just said I need both batteries replaced...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kristieq2, Sep 12, 2013.
  1. kristieq2
    kristieq2 New Member
    Niceville, FL
    Hey All-
    I have never owned a Prius before, we purchased a used 2006 in April. No problems with it until I parked it at the airport for 2 weeks and came back to a dead car. I know now that was a no no, but hey, I'm new at this. After that it all just went down hill. The front tire blew, I had it fixed and magically the AC went out. Then I let it sit again for a week or two and the car was totally dead. Okay, no big deal, I jumped it with my jeep, everything was fine. This happened again a few days later and EVERY single warning light came on the dash. I called the Toyota dealership and they told me to bring it in and that it probably just needed a computer reset because the battery had totally drained.
    I bring it in today, en route I was having an anxiety attack because the main battery was not charging from the engine at all and it was the equivalent of driving a go cart that has zero acceleration. I was terrified! I make it to the dealer only for him to tell me that the starter battery AND the hybrid battery are goners and that it would be upwards of $3,200 to replace. Yikes! I knew that this car was going to need a new battery eventually so I'm not totally shocked.
    My question is, how do I go about finding a used battery? This car has 204,000 miles on it already so I hate to spend that much money on the batteries when there MUST be a cheaper alternative. My husband is deployed otherwise I would have him doing this research but I am stuck trying to resolve this issue on my own. Any and all advice would be greatly appreciated. I am located in Northwest Florida if that makes any difference in locating places to look.
    Help and Thanks!!!
  2. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I'd call around to some independent shops in your area and also search on Yelp for ones that may specialize in hybrids. They often have good sources to salvage yards to locate a used main battery for you for way less than a new one.
  3. BFAyer
    BFAyer Junior Member
    Gloucester, VA.
    It sounds more like the inverter to me.
    Jump starting is the number one cause of failed inverters.
    I would replace the 12 volt battery and test the inverter before I spent any money on a new hybrid battery. The bad news is inverters are more expensive than batteries.
    Not that it matters now, but if you have smart key, use the disable button next time you park it for a few days. That will keep from killing the 12 volt battery.
  4. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Here are some mail order sources for 12 volt batteries for the Prius.
    Exide AGM Car Battery (Group S46B24R)
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + , Prius V & Plug-in Prius with Instructions
    If you get the terminals wrong, even for a second, you will do several thousands of dollars of damage to the Inverter, which is why I recommend the little jump-start chargers instead of attaching to another car.
    Should it turn out you need a different HV Battery, used starts at about $800 DIY to $1800 installed
    2006 Toyota Prius Base 1.5L in Charging & Starting Systems | eBay
  5. Patrick Wong
    18,200
    6,493
    Have the 12V battery replaced first to confirm that the driveability symptoms (traction battery not charging and low power output) persist.
    Ask your dealer's service writer for the DTC logged by your car. I would agree that the diagnosis of a failed traction battery appears to be reasonable given the symptoms you described.
    Assuming that the traction battery needs to be replaced, you will need to find an independent mechanic who specializes in Toyota hybrids who can help you to install either a used battery from a salvage yard or a "remanufactured" battery which is one step above a used battery and has a one year or two year warranty. Good luck.
    If the OP is able to jumpstart the car and the car will run, then the inverter is not at fault. If she had screwed up the jumpstart polarity, at minimum some fuses would pop which would cause the car not to become READY. So that is not a concern.
    Merkey, uart, SteveLee and 1 other person like this.
  6. uart
    uart Senior Member
    4,220
    1,209
    Australia
    It sounds like an unusual string of problems given that there's no causal relationship between *any* of them. Perhaps this is a case of being sold a lemon, as in someone who knew that the car had a number of problems and just cleared the codes and patched things up etc to get it sold. :(
  7. Patrick Wong
    18,200
    6,493
    It appears that the OP had the following problems:
    1. Weak 12V battery (this will happen especially if the car is not regularly driven. If the battery is original equipment it is ~7 years old and way past-due in being replaced.)
    2. Front tire blew (not the fault of the Prius. This typically happens due to impact with road debris or severe underinflation causing damage to the tire)
    3. AC went out (if the condenser was the problem part, that may be related to #2. If #2 occurred after hitting road debris, that debris may have also damaged the condenser. Otherwise, this would be a random failure associated with the car having logged 204K miles.)
    4. Bad traction battery (after the car has logged 150K miles, there should be no surprise when the traction battery dies.)
    The Prius is way past end-of-life at 204K miles and some amount of remedial repairs will be required from time to time.
    The Critic and GrumpyCabbie like this.
  8. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    I wonder if the inverter pump is failing - the overheated inverter would shut off power to the A/C to protect itself, and send the car into limp mode (no power, no HV charging), and show a bunch of scary warning lights.
    nh7o likes this.
  9. hill
    8,641
    Pat is right on when it comes to a 7 year old 12 volt auxiliary battery. But any 7 year old car with >204,000 miles can't be said to not be driven regularly. I mean jeez ...even if it were only driven every other day - that's over 160 miles round trip ... every week of every month of every year. That poor Prius has had the dog snot driven out of it
    IMO, the best case scenario would be that a battery pack can be rebuilt out of used modules. Plus, some folks get rebuilt packs done for under $2k. - turning on how many bad modules there are in the bad pack. I would look into that myself. That's cheaper than buying a whole new car.
  10. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Cheaper alternative if it actually needs a new traction battery? Sorry but no, there really isn't one.
    Make absolutely sure that the stealership isn't taking you for a ride. They will if you let them. Get a second opinion from an independent hybrid specialist in your area so you don't get ripped off.
    So you bought it five months ago and it now has 204K miles on it? How many miles did you put on it in five months? Seems as though you bought it with nearly 200K. Depending on where the car was driven the last seven years (hot and hilly locations are traction battery killers) and the TLC or lack thereof it received, you took a BIG risk and may have lost out big too.
    You have two options:
    1) Replace the bad traction battery with a re-manufactured one for about $1500 installed (you aren't going to be able to DIY if your husband is deployed) and pray that's all it needed.
    2) Sell it as is to someone who really wants a Prius (or another one :) ) who will replace the traction battery as they see fit. You might find someone (probably someone who already owns a Prius) willing to pay you $3K or more for it in its present condition.
    Your best option IMHO is 2. To be blunt, this is beyond your ability to handle on your own unless you know someone who can help you while your husband's away.
    Hope you didn't pay too much for it. It's always risky buying a used car, particularly a hybrid - especially one that's 7 years old with mucho miles on it.
    Best of luck to you no matter what your ultimate decision is.
  11. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Be sure to keep us updated with your progress as the accumulated info is helpful for the knowledge base.
  12. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    "My question is, how do I go about finding a used battery?"
    Without knowing where you are (Country, State or Province) we can't recommend a nearby source.
    Here are some.
    Our Installers
  13. sportcoupe
    sportcoupe Junior Member
    44
    I've seen used traction batteries go for $900 installed on my local craigslist if you're looking to save a buck and are unable to replace failed modules yourself.
  14. hill
    8,641
    There's a potential world of difference between a used pack and a rebuilt one. IMO, I would start to become leary when the price gets that low.
  15. sportcoupe
    44
    Agreed but a "rebuilt" pack most likely only had the bad module(s) replaced to which it is still a "used" pack and a warranty is only good as long as the re-builder is still in business.
  16. kristieq2
    Niceville, FL
    Thanks for all of the replies everyone!!!
    I had to step away from the issue for a few days, I'm 8 months pregnant and that post about inverters made me cry.
    We did not pay a lot for the car, only $4,000...we definitely realize it was risky to buy an old hybrid but we took the risk because the savings in gas compared to my husband driving 40+ miles to work every day in his jeep wrangler would have paid off once he put about 20k miles on the Prius. Maybe you're right, it is possible the seller got the last laugh (and four grand). That being said, we do live in Florida and it is extremely hot here so that would make sense in adding to the stress of the battery. We bought the car at 200k miles so he had already put on a few thousand miles. I have made some calls to junk yards, etc. and they are willing to help me look for a used battery (saying around $1300-$1400 plus the $300 for Toyota to put it in...I haven't found a single place that works on hybrids here). So far we are thinking that if we can find a battery for a reasonable price (DEFINITELY not one from the dealership) and drive it for maybe another year then we can sell it or use it as a trade in and it wouldn't have been a total waste.
    I won't give up on Prius' though! Just a string of bad deployment luck but next time we will definitely be buying one directly from the dealer. You can't win them all i guess.
  17. 2009Prius
    2,705
    511
    63
    I would get a second opinion to make sure the HV battery is indeed bad before spending time and money on a used one. Ask the dealer for the DTCs and post here.
    I would follow Patrick's suggestion:
    I would check the inverter coolant pump - look into the inverter coolant reservoir for fluid movement with the car in READY mode.
  18. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    A "dead HV battery" is usually a false sign of something else. Fix one thing at a time, and do the diagnostics as already explained above. The fact this all started after multiple dead 12v batteries and jump starts, makes me nervous.
    Merkey likes this.
  19. kristieq2
    Niceville, FL
    You guys have been so helpful. Thanks again.
    So I am thinking of all the options, I want to make sure we go the right route.
    On selling the whip and moving on...
    Do you think this car would be worth anything as a trade-in for a new vehicle?
    Or should I just post it on Craigslist and hope for a miracle?
    One way I have been looking at it is that I could spend all of the money on repairs or I could see that money going toward monthly payments.
    Decisions, Decisions.
    Basically, when selling (if I so chose to go this route) which is the best avenue?
  20. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Have you replaced the 12V battery yet Kristie?
