Help! (duplicate post)
Discussion in 'Prius v Main Forum' started by BartmanLA, Aug 12, 2018.
  1. BartmanLA
    BartmanLA Junior Member
    2015 Prius v wagon
    Cleaned Hybrid Battery cooling system, to be safe (worrier herer) I pulled the Hybrid Batter Interlock, after I put everything back in I got a "Hybrid System Malfunction" and the car won't start. How do I resolve this??? Please? I posted in the Technical Forum on this as well. I'm worrying as I need the car tomorrow. Thanks.
    49,500
    generally, people forget the last step. slide after snapping down.
    if not, check the wiring at the fan.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,979
    4,722
    Texas Hill Country
    The disconnect is a fuse that could be checked. I have heard of some who did not get it in all the way so I would take it out and try again.
  4. BartmanLA
    2015 Prius v wagon
    Double checked the interlock plug was slid over to LOCK. Read on a few other places that you have to power cycle the car a few times. I made the mistake of freaking out when I saw the message and immediately powered down the car, never giving enough time for engine to even start up. Once I did it about 6 times the message stopped appearing! Whew! Thanks guys for all your help, I just wanted to be sure I got everything done right. Especially being able to save about $300+ on the Dealer charged cleaning of the battery cooling system, lots of dust and dirt in the inlet cover screen, now it's all clear.
    Raytheeagle and bisco like this.
  5. bisco
    49,500
    well done!(y)
