HELP!!! Engine and Invertor Coolant.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Mr. Otari, May 15, 2021.
  1. Mr. Otari
    Mr. Otari Junior Member
    Georgia
    Hello guys, today I checked the coolant reservoir for both engine and invertor and found out that there is low coolant in both of the reservoirs. I tried to find genuine coolant (from the owner's manual) for my gen 2 Prius but no one sells it, so I have some questions.
    1) which coolant should I use in my Prius?
    2) Can I just add it or replace it all?
    3) how many litres should I buy?
    Here are the images of low coolant:
    Thanks in advance.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,964
    4,709
    Texas Hill Country
    Toyota dealer or Amazon
  3. PriusCamper
    PriusCamper Senior Member
    11,093
    4,515
    Pacific Northwest, USA
    You want to use the red coolant for asian cars... Either use Toyota brand of there's this coolant I buy that Valvoline makes that says its specifically for Toyota, Lexus and Scion. It sells at a much lower price and seems compatible with no issues thus far:
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,461
    1,505
    NJ-USA
    My personal preference is to use the Toyota (super long life pink) coolant if possible. Otherwise I would top up with something like Zerex (valvoline) Asian Vehicle (red) coolant. Be sure to check the actual level in the radiator- not just the white plastic tank.
    If the radiator level is low, you might want to figure out where the coolant went.
