Help, how to remove passenger side Door Panel
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by EC15Prius c One, Dec 14, 2015.
  1. EC15Prius c One
    EC15Prius c One New Member
    San Francisco
    2015 Prius c
    Someone broke my passenger side mirror..... I just purchased a OEM mirror. I guess I need to remove the door panel to install the new mirror. Does anyone know how to remove the FRONT Passenger side door panel?
    I have the 2015 Prius C One.
    Thank you so much for the help!
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Most door panels are easy. I would start behind the inside door handle there is usually a screw or two. Then look in the arm rest. Might be one there. Then everything else is usually clipped in just be careful when pulling off the door handle.
