HELP! Hybrid battery died.
Discussion in 'Gen 2 Prius Main Forum' started by Desert Flier, Apr 24, 2021.
  1. Desert Flier
    Desert Flier Member
    68
    Phoenix
    Weekend greetings! I got the red triangle of death this morning with all of the associated chimes and other lights. Battery charges up and depletes within minutes. Sometimes won't charge at all and shows one bar. I will confirm codes with my Techstream and update the post when the car gets towed home. My question is simply what is the best company for a replacement hybrid battery. I can do the work myself and would pay extra for plug and play but am capable of tearing the pack down and building it up of needed. For the record I'm not interested in changing out one or two bad cells. I'm looking for a complete rebuild. I know this info is on here somewhere but I'm in a time crunch so I apologize for asking a question that has been asked hundreds of times and posting it in the general forum. Just in a pinch.
    Dave
    C Wagner likes this.
    52,368
    drone13, bmparent, C Wagner and 2 others like this.
    52,368
    duplicate
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    C Wagner and Desert Flier like this.
  5. ChapmanF
    18,521
    Don't spend money before reading the codes. It could turn out you've got one of the other couple hundred reasons for that triangle to light up.
    chronon, C Wagner and Desert Flier like this.
  6. bisco
    52,368
    except for the rapidly fluctuating battery icon
  7. alftoy
    alftoy Senior Member
    1,132
    518
    Saskatchewan, Canada
    Earnhardt Toyota $1657.50 Online? Probably.
    Auto parts Mesa, AZ | Earnhardt Toyota
    Camelback Toyota $1699
    https://parts.camelbacktoyota.com/oem-parts/toyota-battery-g951047031
    #7 alftoy, Apr 24, 2021
  8. ChapmanF
    18,521
    If somebody wants to precommit $1700 based on that before asking the car what it wants to tell them about, I guess I can't stop them.
    C Wagner and jerrymildred like this.
  9. bisco
    52,368
    did the price go up?
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    @ChapmanF is right. Make sure it's really bad before you spend four figures on replacing it. (Which I assume from your original post, you intend to do.) At that age, a failed battery wouldn't be surprising, but it could be corroded wiring or other things.
    If it is the battery, the two best options have already been supplied -- Toyota or New Prius Batteries. Next best would be a near new used one from a junkyard.
    tangerino, C Wagner and Desert Flier like this.
  11. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Does the HV battery fan located near the back passenger seat run at a higher, or more audible speed ?
    Assuming you need such, and If you have some time and a few extra bux, you might want to get in line for the new lithium pack.
  12. Desert Flier
    Desert Flier Member
    68
    Phoenix
    OK thanks for the replies. I had a little time tonight to check some codes. P0A80, P3023, P3000, C1310. Battery fan is running on high continuously until I reset codes. Once codes are tripped again the fan runs on high. I inspected the fan and ducts a year ago when I was repairing a hatch seal leak and they looked very clean. The inlet to the fan seems to be pulling air easily. Looking at live data block 13 was always 1.0 volt lower than the rest of the blocks and at one point was 1.24 volts lower. All other blocks seem to be behaving normally. Cleared codes. Same codes came back within a few minutes. Engine sounds "different"...idles up and down slightly and acts like it's under a slight load at times while in park. On the information display screen I noticed that the battery would indicate anything from fully charged to fully depleted within just a few minutes while idling in the driveway. A few weeks ago I started noticing that the display showed the batteries charging and depleting faster than in the past (I'm not the primary driver so I didn't think too much of it). The other morning I started the car and noticed that the indicator showed 1 red bar after sitting overnight. The previous night the car was just driven home about 10 miles and parked without any idle time.
    Tomorrow I will disconnect the 12V battery and test it to see how healthy it is and recheck tech stream data. I don't know the history of this battery as I bought the car used. When I had the trunk apart last year I noticed some yellow crayon/chalk writing on the battery case that did not seem like something you would see on an OEM battery so I am assuming the original battery has been replaced or worked on.
    Members seem to like newpriusbatteries.com or OEM from dealer. I have also researched:
    Greentecauto.com NEW upgraded capacity cells with 48 month warranty plug and play $1650.
    Greenbeanbatteries.com. RECON high capacity cells, lifetime warranty, includes plug and play installation in my driveway $1450
    Dave
    tangerino and C Wagner like this.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    You can NOT "recondition" old cells.
    Unless you want to repeat this problem over and OVER, any company that only replaces the "bad" cells in a pack probably is not a good choice.
    It is a big gamble and the odds are against you.
    bmparent, C Wagner and 2k1Toaster like this.
  14. ChapmanF
    18,521
    Ok, I was waiting for those, but now that you have them, they are completely consistent with the problem being the traction battery.
    Little need for that that I can see. Sometimes it's suggested that the ECUs make up 'bogus' codes because of 12V battery issues, but even if you buy that idea in the abstract, you can see in your case that you have a set of codes that's internally consistent, makes perfect sense, and matches up with other symptoms you're seeing.
  15. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Sam,
    An "old" module often has a lower capacity because the 6 cells inside the module have drifted apart in their State Of Charge. Rebalancing a module gets all 6 cells to the same SOC and regains some lost module capacity. This is a tested and proven fact. The rebalanced module does not regain the full capacity of a new module, but the procedure does lengthen the module's useful life and makes a "reversed cell" less likely which immediately ends a module's usefulness.
    JeffD
    C Wagner, alftoy and Raytheeagle like this.
  16. alftoy
    1,132
    518
    Greentecauto.com NEW upgraded capacity cells with 48 month warranty plug and play $1650 48mth warranty??
    Same price as new Toyota battery.
    #16 alftoy, Apr 25, 2021
  17. jdenenberg
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I think that you will find that a replacement Toyota battery does not have a 10 year warranty, but it is likely to outlast the rest of the car. I was unable to find any actual specification of the "upgraded" capacity of the Greentecauto cells on their web site.
    JeffD
  18. sam spade 2
    7,035
    2,804
    2017 Prius c
    And that is because they are wearing out at slightly different rates.
    You can not reverse that or really make up for it.
    But believe whatever you want.
    Legions of owners have found that what you propose turns out to just be a huge pain in the a s s.......and mostly a waste of time.
    Actually battery scientists found that out maybe 40 years ago but some urban myths die hard.
    My considered opinion is: Suggesting to the "average" owner that a "reconditioned" battery is a good choice.......or that he do it himself.......is just not responsible advice.
    Desert Flier and C Wagner like this.
  19. Desert Flier
    Desert Flier Member
    68
    Phoenix
    tangerino, C Wagner and bisco like this.
  20. bisco
    52,368
    that's a great price, and the route i would go if i could get it.
