Help! I am wondering if i am in endager to any electrical problems
Discussion in 'Gen 2 Prius Audio and Electronics' started by Jonathan Padilla, Dec 4, 2013.
  1. Jonathan Padilla
    Jonathan Padilla New Member
    Hey everyone,
    I currently have a Sony GS-600Bt for the stereo
    C2-600 Front and Rear Coloxial
    C5-075 for tweeters
    power by a JL 400/4
    With a W3V3 at 2ohms powering by a JL JX 500/1
    I was wondering since im running 900 RMS Watts, am i endager of any electrical problems?
    I have them directly connected to my 12 volt factory battery?
    Please HELp!
    PS: 2005 Toyota Prius non JBL
  2. Britprius
    Britprius Senior Member
    5,194
    1,916
    Herefordshire England
    You will have no problems provided when using your system while stationary you have the car in ready mode and park. This way the car will look after the state of charge of the 12 volt battery.
    If the battery is the original or more than four years old replace it now as it is on borrowed time.
    John (Britprius)
  3. Jonathan Padilla
    Any battery brands you reccomend?
  4. Air_Boss
    Air_Boss Senior Member
    3,953
    1,085
    New Yawk
    As Britprius said... But how's your hearing?
  5. Jonathan Padilla
  6. Jonathan Padilla
    The hearing is good the jl audio xd 400/4 , brings the life out of any speaker haha , but the tweeters does wonders , I like listening to rock sometmes and it brings out the guitar solo really good
  7. Jonathan Padilla
  8. Britprius
    5,194
    1,916
    In my opinion the Exide Edge FP-AGM51-JIS is a better battery for your needs than the Optima. The main reason I say this is because of it's higher capacity "45 AH against 38 AH". It also has a longer full replacement guarantee at 5 years. It is comparatively priced with the Optima.
    If you do not mind minor modifications to the battery terminals go for a 55 AH mobility battery. See my post
    Fitting mobility 12volt AGM battery.
    John (Britprius)
