HELP IDENTIFY! Engine covered in oil.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Skimonster, Mar 14, 2022.
  1. Skimonster
    Skimonster New Member
    Portland
    Can you please help me identify what is leaking? Oil covers front of engine up to valve cover and all of passenger side of compartment and under engine covering oil pan.
    I bought car salvaged at 80k. It's at 140k now. It had minor body damage. I do all maintenance, oil change at 5k but i dont change the plug seal. I add Lucas oil additive every time which I'm thinking is the cause of my issue by increasing the crank case pressure. I have my suspicion the timing cover is leaking. I am in process of changing PCV valve and installing oil catch, clean egr cooler, oil pressure switch, plugs, clean header and throttle body, replace water pump and thermostat while im at it.
    My question is what is leaking? If its the timing cover should I just do an entire timing job and any links to write ups known of?
    Any advice or experience would be great!
    20220314_181913.jpg 20220314_181935 (1).jpg 20220314_181923 (1).jpg 20220314_181913.jpg 20220314_181935 (1).jpg 20220314_181923 (1).jpg
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,232
    5,934
    Columbia, SC
    Looks to me like you have an awful lot of oil stains coming from the filler cap area and running down the front of the engine. Either someone has poor aim while filling or you're venting a lot of oil/vapor from the cap.
    StarCaller likes this.
  3. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    The last half of the pcv hose that goes to the intake manifold is covered in oil.
    Maybe that pcv to intake manifold connection is not sealed well by that spring clip, allowing oil to be blown back onto the engine block by the radiator fans and air flowing through the radiator?
    There's a lot of fresh, dark oil right under that area as well. Possibly from dripping oil from that connection.
    #3 xliderider, Mar 15, 2022
  4. Skimonster
    Portland
    Good eye. You sir are correct, I in fact have terrible aim. One of my theories is I'm not tightening the oil cap enough but I have a hard time believing some oil Spillage every 5k change can cause that much build up. Basically everything that should be silver color is black.
  5. JC91006
    16,482
    8,400
    With any salvaged vehicle, this engine may not even be the original engine to this car. Have you run a carfax to see if there are mileage discrepancies to your car?
    It may have been damaged in the front of the car where the engine was exposed for a period of time. Fluids/oils get on the engine and dirt would collect on there. Also the workmanship of the person that put the salvage car back together can also be questionable. These cars are usually put back together for quick/maximum profit when sold.
  6. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    this^
    good thinking!
  7. Skimonster
    Portland
    I would agree buying salvage cars is questionable but I did all repairs my self so I know what the actual damage was.
  8. Skimonster
    Portland
    I hope you could be correct. I'll look at the can to see if vapor residue is in it. However the oil pan has a lot of oil on it underneath as well. Would a pcv leak cause residue below and on passenger side? It's also mm thick
  9. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    Valve cover gasket looks ok... Pretty low mileage for it to have had headgasket work, but it sure is a mess from that gasket downword...
  10. Skimonster
    Portland
    I should also mention oil puddling in throttle body and my mug is at
    My first thought was val e cover initially but that seems secure. I thought timing cover due to it being a know issue. I'm leaning towards pcv issue. Best I'm going to do is probably Clean engine up and monitor for location of oil seepage.
  11. xliderider
    7,872
    3,116
    Honolulu, HI
    Oil pooling in intake manifold below the throttle body is normal without an oil catch can. In your case, you might have excessive blow by with more than normal oil going through the PCV valve and hose.
  12. jerrymildred
    jerrymildred Senior Member
    11,516
    14,120
    Tampa, FL
    I have a half-joking theory that, given enough time, one drop of oil will eventually spread to cover the entire planet. Except that it doesn't go up hill. The highest place I see with more than a tiny amount of oil on it is in the vicinity of the oil cap.
  13. xliderider
    7,872
    3,116
    Honolulu, HI
    Oil will normally not flow "uphill", but air normally flows through the radiator and there are radiator fans blowing hot air, which will also help spread the oil out over a larger area. Maybe even push the oil "uphill", in this case.
    jerrymildred likes this.
  14. PriusCamper
    11,106
    4,520
    Yep, you can't diagnose & repair with certainty until you get it all cleaned up and see if it starts to come back or if it's just previous owner's mess not related to an actual engine problem. When you first got it at 80K miles do you think it looked like this?
