HELP! --Identify severed wires on RH Gen3 Prii.
Discussion in 'Newbie Forum' started by svldvc, Feb 20, 2021.
  1. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    HELP!!
    2011 Prius got hit in the RH corner, destroyed the headlight completely.
    Severed a batch of wires.
    I'm pretty handy and done wire work before.
    Need help identifying colors and what wire goes where please.
    See my pics below.
    Wires to identify:
    1. Thick Purple
    2. Thin Purple
    3. x2 Thin Brown ones
    4. Thick Brown (long one)
    5. Red
    6. White + Black stripe (housed together with the red one)
    7. White & Black (Intertwined/twisted together) - very long
    I'm hoping a few of these go to the airbag crash sensor that is mounted on the side of the frame. The wires were yanked out if it.
    [​IMG] [​IMG]
  2. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    nobody can help?
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    Try going to a wrecking yard to get that part of the harness. Otherwise, try to see if the dealer can order you the pigtails going to the marker, head and running lights.
    svldvc likes this.
  4. Elektroingenieur
    2,515
    3,259
    Three Touring
    The Electrical Wiring Diagram (more info) contains this information, along with the part numbers for connector housings and repair wires (pigtails) with pre-crimped terminals.
    svldvc likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,231
    5,934
    Columbia, SC
    There probably aren't many people with a Gen 3 that have photos of that area just laying around or that want to disassemble their car to take them. On the other hand, I've purchased a repair manual for every car I've ever owned and they've always had wiring diagrams, with color codes. I've never owned a Gen 3, so I don't have a manual. Perhaps that would be your best option.
    svldvc likes this.
  6. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Thank you all for help. You guys were helpful.
    It's my friend's car so was trying to help him out.
    I just know first hand that here are Priius gurus that can identify stuff just with a blink of an eye hehehe :p
    So I figured I'd give it a shot and post the pics.
    Got most of them already identified (except the x2 thin brown cables and the red+white).
    Got my headlight and airbag pigtails wired in already.
  7. ChapmanF
    15,653
    The Electrical Wiring Diagram is definitely where you find all of that information, as Elektroingenieur posted. Toyota does sell repair terminals, already crimped to short lengths of wire, and the part numbers are in the EWD. But they are not as cheap as you'd expect a little terminal crimped on a short piece of wire to be, and the bill if you have to buy a dozen of them gets kind of annoying. At that point, trying to find a good-condition harness in a salvage vehicle to hack off the damaged part of the harness from can become attractive, as Georgina suggests.
  8. TMR-JWAP
    6,231
    5,934
    Columbia, SC
    The pull-a-part in my area shows they have a 2011 in stock. I may get out there Saturday. If so, want me to see what I can chop out of it?
  9. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Thank you so much for the offer.
    Wow, you're in Columbia, SC. We're practically neighbors (Charlotte, NC).
    I think I pretty much got most of the cables figured out and already ordered the airbag clip on ebay for cheap.
    Also the headlight pigtails got some aftermarket ones and they work great.
    I'll keep you posted if I'll need one more, but so far seems like everything is already connected.
  10. darkeagle
    darkeagle New Member
    Would you mind sharing what the red wire was for? I had some squirrels eat through my wiring, so I am currently repairing that same harness. That is the only wire I can't seem to figure out.
