Help Identifying a Leak (Engine Block Coolant Drain Plug?)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Purrius, Nov 19, 2024.
  1. Purrius
    Purrius Member
    137
    39
    Northeastern US
    I didn't want to necropost on Den49's thread, but I have a question regarding the same black hexbolt mentioned in it.
    I have a 2010 with 208, 000ish miles. While doing an oil change today I noticed a leak ended up appears to be coming from this bolt?
    Likely unrelated:
    I've been planning to inspect the PCV and spark plugs for current condition, because I'm unsure when they were last addressed, as I only started doing my own maintenance within the last couple years.
    I feel like recently the car is struggling a bit, and I have to push her harder to get up to speed sometimes. :(
  2. ETC(SS)
    6,903
    Leaks are......'interesting' .... at least to me.
    Submariner's rule:
    If you find it?
    It's a leak.
    If it finds you?
    It's flooding.
    So.....
    What's 'leaking?"
    Oil?
    Coolant?
    Rain water?
    Transaxle Fluid?
    How much are we talking about??
    It is a weep? seep? drip? dribble?
    They each have individual meanings.
    Where is the car parked?
    In a garage?
    Driveway?
    An 8oz cup of fluid is....a LOT.
    Spill a full cup of coffee onto your kitchen floor and you will know what you know....
    What's in YOUR gargae?
    Driveway?
    Deets!!!!
    Are you the original owner?
    Does the phrase "EGR cooler" mean anything to you?
    What's the coolant level? Oil? Coffee carafe?
    Has the bottom end of the engine been replaced (yet?)
    Maintenance history?
    If you're the 2nd (or 3rd....4th...etc...) owner then you must presume that 'your car' has a 'history.'
    This is nothing to be ashamed of.
    We all have 'histories.'
    PRESUME that YOUR car has its original head gasket, plugs and coil packs, oil filter, and that the EGR circuit hasn't been cleaned.
    PRESUME that this is a factory-maintained vehicle, and that you're 80,000 miles past the extended factory warranty period - which means (according to Toyota's philosophy) that they've met their obligation to produce a 'good' car.
    Me?
    I'd start looking at fluid levels more often and I'd replace the plugs IMMEDIATELY - not because the plugs are wrecked but rather to give you the opportunity to look at the plugs and maybe invest $50 in a borescope, and maybe look into the holes.
    Also...
    If you start to get the "Prius Death Rattle" ......STOP DRIVING IMMEDIATELY.
    You will not have to wonder if this is occurring.
    Good Luck!!!
  3. Purrius
    Purrius Member
    137
    39
    Northeastern US
    I appreciate the long detailed answer! I'll address each part when I have a moment. :D
    Is it possible to identify the bolt/plug in the meantime? She's going into the shop for the inverter coolant change in the morning, and I'd like to mention it to them real fast.
  4. Purrius
    Purrius Member
    137
    39
    Northeastern US
    I have no idea what's leaking. I'm colorblind, which doesn't help much.
    Usually outside in an unpaved driveway. I'm in a temperate climate.
    Driveway?
    Currently it's been in the driveway, so unfortunately I don't know how much had leaked previously from the spot. When it was in the garage I didn't think to check before doing the transmission fluid change, so I'm unsure if there was anything there either. That certainly means it wasn't a coffee cups amount though, I'd think. :censored:
    I'm the second owner, but I have owned it since 2012 I believe. The first owner only least it, so all the maintenance was kept up to date by the dealership.
    If that's the part folks here have cleaned every so often, yeah. I've already had it cleaned once within the last 3 years (it looked very rowdy.) It's something I think I could do myself when I have to next time though.
    I just had the inverter coolant changed last week, and I'll be doing the engine coolant sometime in the near future. (Inverter coolant was overfilled by the shop by maybe 3mm, which is probably in consequential.) The engine coolant is between the full and low lines.
    Oil? Coffee carafe?
    I just did the oil/filter recently, so it's all topped up and good.
    Has the bottom end of the engine been replaced (yet)
    ... Is that a thing I should be planning for? :eek:
    The first owner only leased it, so all the maintenance was kept up to date by the dealership.
    For the most part I'd adhered obsessively to maintenance myself up until recently. Without divulging too much, I've suffered a lot of loss in the past year, which caused me to fall really deep into a depression. Pretty much everything has fallen to the wayside, and I have a hard time keeping up with things I used to enjoy or even things that I need to do. (Both ironically being maintenance on my vehicles.) Heck, even the oil change was overdue and I used to do those on the earlier side.
    The head gaskets are original, I'm unsure about the coils, spark plugs have been done within the last 3 years, EGR was cleaned as previously noted.
    Me?
    I do have a brand new set of spark plugs ready to put in, it comes down to finding a warm location I can do it and pushing myself to do it.
    Also...
    If you start to get the "Prius Death Rattle" ......STOP DRIVING IMMEDIATELY.You will not have to wonder if this is occurring.
    Previously when the car sounded like a rowdy diesel engine, it went away when the EGR was cleaned, thank god. Is it like that sound?
    Good Luck!!!
    Appreciated!
    Here's a couple more photos I took while changing the transaxle fluid this week. I'm still not sure where it's coming from.
  5. ETC(SS)
    6,903
    OK.
    So....
    1. I fix telephones for a living. NOT cars.
    2. If your car was 'dealer maintained' by a scrupulously honest and thorough dealer, then it was only marginally maintained - AT BEST.
    I do not say this because I think that dealerships are less than honest (although they 'sometimes' are!)
    I say this because dealerships hue to a 10,000 mile OCI - or oil change interval which is insufficient to the task.
    If you want to keep 'stuff' out of your intake and oil you need to change fluids and filters more often than every 10,000 miles
    Your car has (according to your OP) more than 200,000 miles - which means than in 'human' years it is more than 90 years old.
    You have to treat cars that are that old a little differently.
    Toyota DID their part.
    So may have their dealers.
    TL ; DR
    IF you are doing YOUR part (checking fluids) every 30 days or 1000 miles and the levels are not dropping significantly (measurably) then you're doing your bit.
    @ 'Bottom end'
    No. It would appear that your engine in OK for now.
    MAYBE even REALLY OK. - like you will go 300,000 miles.
    Unless there are puddles and you're losing fluids - the photos indicate 'weeps' or 'seepage' instead of leaks.
    G3 Priuses are known for having a timing chain gasket leak - which is really just a seepage.
    Even IF it's an 'oil leak' and if you're checking your oil every 1000 miles or 30 days per the maintenance manual AND you're keeping your oil level between the dots then you're golden!!
    What ALL OF this means to you is that the stuff in your photos likely a 'seepage' - and NOT a real 'leak.'
    Think of this like your own body.
    You have about a gallon and a half of blood volume...or nearly 200 fluid ounces.
    We are encouraged to donate a pint of blood every now and then (3 times a year more or less.)
    It's not a perfect analogy because oil and blood are different and Priuses have an insufficient 'blood' volume (about a gallon, including the filter)
    A fluid pint is two cups of blood - which YOU WOULD FIND - even in an unpaved driveway.
    My point is....if you're 'bleeding' then it means you may not necessarily have to go to the hospital IF you KNOW where and why.
    'Sometimes' - 90-year-old humans 'lose fluids' because they're.......90 years old.
    We don't take then to a hospital for cuts and bruises.
    Get that checked out!
    Again - I'm just some internet rando - and I am an electronics technician - and NOT a doctor.
    FIX YOU FIRST - then worry about the &%$#! car.
    My own biases lean towards faith-based counseling - but that is MY bias.
    Military and Law enforcement are over-represented in self harm as a result of clinical depression - so if you are perhaps a member of one of those communities then this warrants immediate and thorough attention if it is 'life style affecting' - most especially because those communities lean away from 'feeling sorry for themselves."
    There is a cultural bias in this nation against mental illness which is unfortunate because we often laud cancer or traumatic injury victims as 'courageous.'
    Depression that affects your day to day life IS a mental condition just as a common cold that affects your day to day life is a physical condition.
    Six weeks of cold symptoms (more or less) warrants a visit to a medical professional.
    -jest sayin.... ;)
    Good Luck!!
    #5 ETC(SS), Dec 5, 2024
  6. Mendel Leisk
    40,454
    If the leak is oily it’s not coming from engine block’s coolant drain. It’ll only be leaking coolant.
    I’ve been to that; it’s a smallish bolt and IIRC a socket head cap screw, has an Allen-Key style pocket. It’s up high on the block, ‘round back, near passenger end of engine (aka front of engine). There’s a small spigot protruding, directly below it.
    To “drain the block” you loosen that bolt and coolant flows from the spigot. That block draining yields less than 1/4 cup coolant, not really worth the effort.
