Help identifying a wire plug
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tim-Prius, Aug 14, 2023.
  1. Tim-Prius
    Tim-Prius New Member
    Nampa
    there is a wire plug hanging from under the car, it’s next to a wiper fluid tank - would appreciate your ideas.
  2. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    Looks weathered and chewed up. If the turn signal and other running lights in that corner are all operating normally, I don't think it's important.
  3. Mendel Leisk
    40,576
    You’re in a much better position to ID, than responders looking at a plug close-up.
    no warning lights on dash?
    AC working?
  4. ChapmanF
    17,334
    It would be a lot easier to identify with the wire colors visible, rather than hidden behind your fingers.
  5. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    I don't see an answer to the obvious question as to whether the washer pumps (as well as lights) function.
    xliderider likes this.
