Help identifying and repairing chewed wire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Margaritaville, Dec 25, 2024.
  1. Margaritaville
    Margaritaville New Member
    Rhode Island
    Hello, This is my first time posting on Prius chat so first I want to thank you all for the help trouble shooting and maintaining my last prius which got up to 240k miles and now my current prius which is at 160k.
    i've made the mistake of parking next to a dumpster that's very popular with the neighborhood rats and now I have a chewed wire, blown fuse, and no tail lights in my 2011 prius.
    I learned of this issue when I realized my tail lights were not turning on and replaced the fuse, under my dash only for it to blow again instantly. This fuse blew once this summer, before there was any evidence of rats in my car, and replacing the fuse fixed the issue. Now it blows right away every time i replace the fuse.
    Now looking under my hood the smell of the rats is prominent along with poop, and i found this chewed wire in front of the inverter. Please see attached image. Could you please help me identify what this wire is, and advise on how you would proceed? I was thinking I could try to fix it with solder and heat shrink or alligator clips? but i have no idea if this is safe or smart.
    I watched a video of someone removing their inverter thinking it was connected to that, but it doesn't seem to be.
    For dealing with the rats I'm going to try cleaning the inside of the car and spraying peppermint oil around.
    Thank you in advance!
  2. Mendel Leisk
    40,285
    To keep rodents out of the interior I would screen all the possible entry points. The main one is cabin air intake, on the passenger side of firewall; you need to remove wipers and metal cowl to access it. See @NutzAboutBolts video on spark plug change for a how-to for that process, video #13 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    there’s a couple more possible entry points at the rear, the cabin air exits, in the corners of the hatch, below floor level. When I screened those recently I opted to remove rear bumper and attached wire mesh cages, secured to the plastic vent frame with screws.
    galvanized steel mesh with 1/4” grid is suitable, readily available from hardware stores.
    for the already damaged wiring in the engine bay, yeah I’d just clean everything and replace damaged sections with equivalent gauge wires, soldering and using heat-shrink tubing at the splices. Crimped butt-connectors are equally secure, but bulkier.
    keeping rodents out of the engine bay is nigh impossible; you’ll need different tactics there, like the one’s you’ve mentioned.
    #2 Mendel Leisk, Dec 26, 2024
    Margaritaville likes this.
  3. ChapmanF
    17,012
    Check the operation of both cooling fans.
    Offhand, I'd say that looks like the pigtail part of a fan motor assembly. If I'm right, I won't be able to look it up in the wiring diagram—I'd be able to find the connector and wire colors for the car's wire harness where that plugs in, but not for that pigtail itself (it'd just be considered to come with the cooling fan motor, not part of the car's wiring).
    Rat got it right close to the connector terminal. Best fix is just buy the repair terminal at the dealer, comes with the right connector terminal already crimped on with its rubber seal and a short length of wire. You pop the old terminal out of the connector housing and pop the new one in. You cut the damaged wire a little farther back, and splice it to the repair wire with a parallel splice and sealant-lined heat shrink.
    What complicates that game here is, if I'm right and that's the fan-motor pigtail end, then the part number of the proper repair terminal won't be what you find in the wiring diagram—the part numbers in the diagram are for the connectors and terminals in the car's harness. You'll want the repair terminal of the other gender but same size/style.
    I've been able to find those before, with a bit of extra work. If you look through the wiring diagram for the various harness-to-harness connections, sometimes you'll find where one uses the same repair-wire part number you found for the car side of this connection. Then the corresponding pin of the mating harness-to-harness connection will have the repair part number you're looking for. (I hope that made sense.) Of course you want to make sure to find the part number for the rubber-sealed/waterproof version, considering where this connector is. A lot of the wire harness-to-harness junctions are inside the cabin and use the unsealed terminals.
    For whatever reason, almost all splice barrels you can buy at regular auto parts stores are butt connectors. Toyota uses parallel splices, which have always seemed more convincing to me anyway. You can find more details through links in this post by Elektroingenieur.
    If I'm right and that's a fan motor pigtail, you might just price a replacement fan motor while you're at it. If it's not too pricey, that'd be a plug-and-play solution to the problem, no looking up terminals, no splicing.
  4. rjparker
    rjparker Tu Humilde Sirviente
    9,336
    5,695
    Texas Hill Country
    Unfortunately rodents often chew many wires.
    While the rodent chewed the black wire of the radiator fan 1, the black wire is ground.
    Top left connector feeds right side fan.
    Each fan has a 30a fuse in the engine fuse box. I would just fix the fan ground wire in place.
    I doubt it is blowing your tail and marker 10a interior fuse. That circuit goes to all four corners of the car. I would inspect the tail and marker wiring up front.
    Then I would disconnect each tail and marker bulb front and back including the license plate bulbs. Remove the individual bulbs where possible and then test with a 10a fuse, a test light or a dedicated current limited device. A bag of fuses might be the easiest
    As far as rodent control, you need to be aggressive with the green poison blocks placed around the dumpster and around the car.
    #4 rjparker, Dec 26, 2024
