Help! I'm falling off the wagon!
Discussion in 'Fred's House of Pancakes' started by David Beale, Jan 13, 2011.
  1. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Well, we just got the most snow over a few days we've had in over 30 years! I was afraid to take Pearl out for fear of getting stuck in the neighborhood (the city ordinarily plows the main streets first, and the neighborhood streets only a few times each winter). I did eventually successfully get out for grocery shopping etc. but had to be very careful to avoid getting off the "beaten path". Good thing I met no oncoming vehicles! Even so I was moving snow due to ground clearance issues.
    So, I once owned an FJ40 Landcruiser (and an FJ65 after that), and now I'm being tempted by an FJ Cruiser. Save me! Even if it's only used as a winter vehicle it's still a gas guzzler.
    Temptation!!
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Yeah, the ground clearance on the Prius sucks. Back in December, we got about 2 feet of snow in a single day, and going out after that I got stuck once... and only avoided it a few other times by building up some speed and powering through it!
    Personally, I'm looking to get a truck (for other reasons, though!) to use as a second vehicle. Mostly runs to home depot and back. But it will be useful while waiting for the roads to be cleared!
  3. Bica2go
    Bica2go New Member
    321
    57
    Boston, MA
    Take a deep breath. Exhale. Relax. Remember, you just had more snow than you've had in 30 years. Think about how much improvement they'll make in fuel economy for the FJ if you wait another 30 years until the next time you get snows like that!
    We had about 20 inches of snow yesterday. I happily stayed home and avoided the mess on the roads.
  4. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    But what if you have to take your sick child to the doctor, it is just like buying insurance without the expectation to use it but to protect yourself.
    The Prius is not meant to be driven in any kind of snow especially the G2. If you are in a snowy area, it is safer to have a second vehicle just in case.
  5. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    Spoken like a true southern. Now it's time to for northern to chime... after taking a moment to look out the window and contemplate how much new snow is falling at this very moment.
    Anywho, Prius is perfectly fine in the snow. It's not built for combat though. The typical depth I've encountered over the past 11 winters (yes, since 2000 with all 3 generations) here in Minnesota hasn't been any trouble.
    Better tires is the key with G2. That's not necessary with G3, since it has the improved traction-control. But upgrading does give peace of mind.
    4 people like this.
  6. icarus
    icarus Senior Member
    4,884
    976
    earth
    Two words: Nokian WRg2s! In the worst case, buy a $20 set of chains!
    Those of us that grew up driving big american boats in the '50's and 60's in northern climes, with no 4 wd,, we all managed to get our kids to the doctor, or get to work etc. We have become so untrained in how to drive in adverse conditions! 2' of snow is a lot, and even the large suv's have trouble navigating. If it is that bad, you don't need to go 99% of the time!
  7. thbjr
    thbjr Member
    326
    63
    Phoenix
    ...or you could move to Phoenix, and shovel sunshine.:D
  8. bisco
    51,141
    we just got 2' yesterday. fortunately, they do a great job plowing around here. we didn't go anywhere, but if we had to, it wouldn't have been an issue. i've driven thru 6" without a problem and it never gets over 2-3 before the plow hits it again.:)
  9. daniel
    14,487
    1,519
    Spokane, WA
    When it snows, I wait for the roads to be plowed before I go out. In a medical emergency, you call an ambulance. Buying a gas guzzler, that you will either use when it is not needed, or leave it sitting and rusting in the driveway, makes no sense.
    Let's say your child has an emergency. You climb in your 4X4 that you bought for this purpose, and then get stopped because the road is blocked by other folks whose cars cannot make it. You call an ambulance, it can go through red lights, other cars have to pull over for it.
    And of course, as John says, if you are really concerned, you put good snow tires on. My 2004 Prius with all-season Hydroedge tires (bought that autumn when John recommended them) handles better than my 1989 Civic did with snow tires. I've never put snow tires on my Prius because I've never needed them.
    But the best thing is to wait for the snow plows. Or buy a snowmobile.
  10. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    My second vehicle is a diesel 4WD truck. I need to be able to get to work in the snow and other bad weather. The truck is for bad weather and truck-stuff.
    I know it's politically-incorrect around here to say it, but if I couldn't afford two vehicles, I'm not sure I'd have a Prius at all. I'd probably have something sensible and 4WD, like an A4 quattro or a small 4WD SUV.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Prius ground clearance is pretty average for a car. It's not great, it's not bad.
    Tom
  12. Zythryn
    Zythryn Senior Member
    6,406
    4,403
    Yep, that is exactly why I have the giant 4x4 parked next to my helicopter parked above my bunker. You just can't be too safe:rolleyes:
  13. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    Yes ,I agree take a deep breath. Would be a big mistake with fuel cost heading the way they are! You may have to get a set of chains or maybe some Blizzak's,<grin>to replace those all season Nokian's!. Hang in there, H
  14. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    If you look at the specs for most passenger cars, the Prius is often within 1/2 inch of others cars, as has been reported here many times. The clearance isn't nearly as bad as you think.
  15. tochatihu
    tochatihu Senior Member
    9,548
    3,683
    Kunming Yunnan China
    2001 Prius
    Hi Dave, long time no hear. I'd agree with several here that the best thing you can do for a snow-prius (or any low 2WD car) is to get real tires. For an ice-prius, chains or straps and drive really slow.
    It will never be a snow plow like a tall 4WD, so let's be realistic about that and not dirve into ditches.
    Too bad Honda no longer produces the 1990-era 4WD civic. That was a pretty nice little 30 mpg snowmobile.
  16. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    Most of you posters did not read the OP. David tells us that they only plow the side streets a couple times each year...David is driving on hard packed snow, maybe a little sand throw on it if he's lucky.
    When people ask me about my Prius, I tell them that if they MUST drive during a snow storm, to get another vehicle. Because of it's ground clearance, the Prius is not made to drive in 12" or more of snow...even with chains....the snow will lift the car...giving you no traction.....
    This is why I have a Olds Bravada AWD parked in the drive.....right in front of my Prius...
  17. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I lived in Buffalo NY for 3 years and drove a Dodge Colt aka Mitsu Mirage. No big deal, although I still shake my head in wonder at the locals who would spin their tyres at intersections and turn the snow into ice.
  18. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Try not to drink so much
    Oh wait wrong wagon
    The last couple of years I have only put on 2,000-3,000 miles per year. Which is why I chose to sell the Prius for a good price and keep the FJ
    My FJ has "real" traction control so combined with factory studded winter tires and 600 lbs of traction sandbags in the cargo area, is generally unstoppable. I have a lot of fun on glare ice in 2H blowing the doors off 4x4's running "all season" tires in 4H
    Since October when I changed the oil in my FJ, I have put on a whopping 600 miles. If this keeps up not only will I need to keep using the Battery Minder, but will probably need gas stabalizer
  19. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    The EV Rav4 will be available soon.
  20. David Beale
    5,963
    1,987
    Edmonton Alberta
    Well, an update. This was all started by our heaviest snowfall in 30 years. Not a lot compared to some, (35 cm) but enough that I didn't even manage to get to the garage for three days and managed to get myself tired and sore shoveling it. We don't normally get enough to justify a snow blower. I usually just use a broom.
    I had to go out for groceries on Tuesday and managed to get around without a problem. Luckily I didn't meet anyone on the side streets so I was able to stay on the packed snow. If I had been forced off by an oncoming vehicle or slid off I would have been high-centred! It was funny as the "more plowed" and "better maintained" major roads, such as the Yellowhead Trail and St. Albert Trail were sheets of ice, while the less traveled and maintained roads were just snow covered. On the ice, Prius does VERY well. -I- was nervous as Pearl was moving about as if she had a flat, but she just went where pointed, stopped better than most other vehicles around me, and accelerated from stops just fine (patience grasshopper!). It was funny watching a full size service van ahead of me turn 45deg to the direction of travel every time he tried to stop! I stayed -behind- him!
    Today they finished plowing the side streets around my neighborhood. So now I just have to dig out the windrows they left at my driveway. :(
    But I'm still tempted by the FJ. I suppose it's the desire to bring back my youth. I had the FJ40 for 11 years when I was young. Went to spectacular places in it. Learned that a 4X4 will allow you to get REALLY well stuck! It had a winch, of course, and I used it often as I was young and foolish. ;)
