Help I'm so screwed
Discussion in 'Gen 3 Prius Main Forum' started by SanGregprius, Feb 20, 2023.
  1. SanGregprius
    SanGregprius Junior Member
    42
    17
    san gregorio ca
    I was changing my transmission fluid. I had to put a smaller tube into a larger tube to fit the fill hole. About 1.5" and when I was pulling out to finish the work the little extension slipped into the transmission.
    I tried a little needle tool to fish it out but it seems to have gone all the way in.
    Any thoughts or have I just cost my self a few $k : (
  2. ChapmanF
    17,326
    Might get somewhere with a little USB inspection camera, and one of those skinny spring grabber thingies.
    SanGregprius likes this.
  3. bettergolf
    bettergolf Active Member
    477
    361
    Sanford NC
    Maybe if you drain it all back out again you can fish it out from the bottom hole....???? I'm not sure if there is a removeable pan at the bottom of the transmission but most cars have that.
  4. SanGregprius
    42
    17
    san gregorio ca
    usb camera sounds like a great idea thanks.
    No pan unfortunately
    talk about self inflicted pain lol
    #4 SanGregprius, Feb 20, 2023
    mikey_t likes this.
  5. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    What was the tube made of? It may be too soft to matter...
  6. SanGregprius
    42
    17
    san gregorio ca
    clear pvc that bends
  7. bettergolf
    477
    361
    Sanford NC
    At least if you drain the fluid back out gravity can help you locate the object...and it may be easier to see in there from the bottom hole. It may find it's way right to that drain hole while the fluid is draining out.
  8. SanGregprius
    42
    17
    san gregorio ca
    I'll try now. thanks
  9. bettergolf
    477
    361
    Sanford NC
    Of course save the new fluid to put back in..........
  10. ChapmanF
    17,326
    Gen 1 had a pan, but not the later ones.
    I'm not sure about the path between the fill hole and the drain hole. I'd be cautious about having the fluid carry the hose to a more unreachable place.
    hill likes this.
  11. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    Have any more of the same material?
    Can you test to see if it sinks or floats in your leftover (or even the old dirty) atf?
  12. SanGregprius
    42
    17
    san gregorio ca
    drained and not feeling any tube.
    Tubbing sinks in atf. Trying to find some diagram online of where it might have gone.
  13. PriusCamper
    PriusCamper Senior Member
    12,048
    4,892
    Pacific Northwest, USA
    Seeing as we're all right now breathing microplastics and they can be detected in almost all parts of our body without too much sickness, maybe your Prius transmission can handle it too? But yes by all means try to get it out first. Just don't pull the transmisison to do it.
    I'd try a USB camera from the top hole with some kind of wire or tool trying to grab it via the bottom hole.
  14. SanGregprius
    42
    17
    san gregorio ca
    pretty tough stuff. hard to squeeze with my fingers. I'd imagine it could clog a port or something. few days till a camera comes.
    In my panic, I realized I posted in Gen 3 instead of Gen 2, which my Prius is. Not sure if this matters.
  15. hill
    8,640
    many tranny type devices have to be siphoned, since there's no drain hole/plug.
  16. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I'm pretty sure the transaxle has a fluid pump and a strainer. Assuming that the tube fell into the transaxle (maybe you actually got very lucky and it's sitting on some of the plastic covers under the car?), I would be very concerned about leaving it in there. Best case is it somehow stays out of the way, but more likely it would get mashed up and clog the strainer, then starve the transaxle of lubrication. Only bad things can happen from that point.
    If ALL else fails, maybe run it for a few miles then change fluid again and see if plastic chunkies come out with it? Maybe look at daily fluid changes for several days? $50 bucks a pop is cheaper than a burned up transaxle.
  17. SanGregprius
    42
    17
    san gregorio ca
    Thanks, I actually was able to get my phone to film video through the drain while shining a light through the fill hole. I didn't see the hose but I did see the strainer and other parts.
    I'm going to hold out at least until the endoscope comes in.
    Your idea sounds good if I still can't find the hose.
    Unfortunately, I vividly remember seeing the hose slip in and even heard a sound like someone dropping a hose into a transmission lol.
  18. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    Hopefully the scope lets you stab it with a needle or hook it on a bent guitar string or something.
  19. SanGregprius
    42
    17
    san gregorio ca
    so close no matter how far... I can't move the grabber any closer. I lastly used a coat hanger and have since rolled the tube by the drain plug, but now need to get the hose vertical to make it slide out. :confused:
  20. Leadfoot J. McCoalroller
    7,856
    7,324
    Pennsylvania
    2018 Prius c
    Can you knock it around with a little compressed air? Maybe a bounce or two and it lands aligned well for departure?
    EDIT: adding:
    maybe air in the top and a shopvac on the drain, so any movement is towards the drain?
    #20 Leadfoot J. McCoalroller, Feb 26, 2023
