Help in S. California. Got a CEL P0A80 on 2005 Prius.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by EkS, May 23, 2016.
  1. EkS
    EkS Junior Member
    s. cali
    Hello! Well I was driving my 2005 Prius with 152k miles today, when I get 4 lights including the CEL and red triangle. I was able to scan with with the Torque program and got a code of P0A80 with no other codes. But I do have Techstream, and I'll be scanning with that in a few minutes. What exactly does the P0A80 mean? Should I start looking at replacing the hybrid battery?
    49,375
    i think so. but you're barely out of warranty, i'd ask toyota for some help.
    S Keith likes this.
  3. EkS
    EkS Junior Member
    s. cali
    Well looks like I also have a code P3000-123 aside from P0A80. I've attached the screenshots from Techstream. What am I looking at here? P0A80.jpg P3000-123.JPG
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    There is a good chance that one of the two modules in block 8 has a dead cell in it. It's not a sure thing only because the overall
    state of charge of the entire battery is only 29.5% which is much lower than it should be.
  5. EkS
    EkS Junior Member
    s. cali
    Anything I can do to determine the actual cause of the CEL?
  6. bisco
    49,375
    besides the fact that you have an 11 year old car with 152,000 miles?
  7. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    Why would you think the P0A80 and the P3000-123 would not be the cause?
  8. johnnyb588
    johnnyb588 Member
    193
    73
    Tempe, AZ
    I
    Block 8 was my suspicion as well. How familiar you are with this type of work, how much time you have, and how willing you are to troubleshoot (play whack-a-mole) will determine your best course of action moving forward (not to mention budget).
  9. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    First off credit to the OP for posting your issue with your codes retrieved from a creditable device! P0A80 is the terminal code for your HV battery. As time goes on I would expect to see d more of this code as the HV batteries are nearing the end of their design life span. Your options as I see them are the whack-a-mole approach and change only the cell(s) that have failed, purchase a rebuilt battery, purchase a used battery or purchase a new battery from Toyota. All of these options are a function of time, money and mechanical abilities.
