help ipod won't play aux input?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Hummerzebe, Jun 17, 2007.
  1. Hummerzebe
    Hummerzebe New Member
    Ridgecrest. CA
    Help, simple question if you know the answer (isn't that always the case!).
    Plugged my ipod into the aux input jack but couldn't get it to play when I turned on the stereo. I have a 2006 Prius - anybody know what the problem might be?
  2. Vagabond
    Vagabond Active Member
    1,198
    Southern California
    <div class='quotetop'>QUOTE(Hummerzebe @ Jun 16 2007, 10:38 PM) [snapback]463330[/snapback]</div>
    what happens when you press play on the ipod? did you press the AUX button on the headunit?
  3. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(Hummerzebe @ Jun 17 2007, 01:38 AM) [snapback]463330[/snapback]</div>
    When you turned on your stereo, did you press the CD/AUX button and make sure it was in AUX mode?
    Did you turn on your ipod and start it?
  4. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I find I have to raise the Ipod volume to more than headphone level to get the car to play properly.
  5. MacDude
    MacDude Junior Member
    71
    Bonny Doon, CA
    I'd recommend getting a Belkin (or similar) unit that plugs into the bottom of the ipod. The signal goes through it cleanly and it keeps the iPod charged.
  6. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    also make sure your aux cable is fully plugged in. The stereo wont go to aux mode if it doesnt detect a cable plugged in it.
