Help, it won't go into neutral!
Discussion in 'Gen 2 Prius Main Forum' started by mpruis, Apr 6, 2005.
  1. mpruis
    mpruis Junior Member
    27
    Michigan
    This has happened three times now, and only at the car wash.
    My 2005 (purchased Oct 2004) with 10,000 miles, won't shift to
    neutral. I'm not sure whether I accidently had touched the Park button,
    in which case you must hold the brake momentarily to allow a shift,
    or if I simply didn't hold the neutral position long enough.
    The car wash attendants are yelling - don't brake, put it in neutral,
    and I'm frantically trying to slide the puck (shifter) to the N position.
    so they shut down the car wash drive train, and eventually the machine
    concedes, and everything is OK,
    Has anyone else experienced this ?
    Mel Pruis , yes Pruis the anagram - from Michigan
  2. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    Always shifts into neutral for me.. hmm.. strange. Did you try.. well.. no.. brake shouldn't be needed * thinks* if you hold it it should go. Just keep holding it in the N position. *shrug* I haven't heard of this happening to anyone else so far.
    Anyone else hear of this problem?
  3. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    I'm betting 10 points that he simply is flipping the knob to "N" and immediately releasing it - instead of holding it in "N" for a second or two.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(priusham\";p=\"79227)</div>
    Yep that's it you have to hold it. Learned that here in a discussion on car washes!
  5. Tideland Prius
    16,445
    Why do they insist on neutral instead of the brakes?
  6. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    From park, you have to press the brake to go to N. I tested this. However, you can go from D to N or N to D without the brake, which is why it is a good idea to put the car to Ig-On, so that if the lever gets bumped, the car won't start driving away unmanned.
  7. V8Cobrakid
    3,790
    152
    Dan: i think he was in the car. Good tip for others though.
    Priusham: I'll take your 10 points :) "I'm not sure whether I accidently had touched the Park button,
    or if I simply didn't hold the neutral position long enough."
    he knows to hold it... knows to use the brake from park too :)
