Help, just bought my first Prius (used) & have a few issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ecochic Kat, Sep 9, 2015.
Tags:
  1. Ecochic Kat
    Ecochic Kat New Member
    Las Vegas, NV
    So, I just bought a 2006 Prius with pkg 6. Finally happy to have gotten my first hybrid and loving the hands free phone, navigation system & back up camera. BUT, thought it was just the batteries in keys so had batteries replaced & still cannot get the car to lock/unlock. Also the one cigarette lighter has no power to charge my cellphone. Can't find anything about these in manual and AutoZone was worthless - said key batteries were dealer items (got those done at a battery store) but they also refused to check the fuses. Any suggestions on how to keep my new baby locked without having to use the manual key to get in & out and how to charge my phone? Thanks in advance
  2. vskid3
    vskid3 Active Member
    773
    228
    There are two cigarette lighters in my 2005, one under the dash to the left of the passenger's legs and one in the center console. The fuse panel is under the dash on the driver side, I believe the cig lighter fuse is indicated on the chart. A blown fuse could also be the cause of your locking/unlocking issues (may even be the same fuse causing both).
  3. JC91006
    16,482
    8,400
    Do you only have 1 key fob? Spare?
    49,504
    could be the 12v, or bad lock actuator. doesn't the manual lay out the fuses? does the door lock/unlock with the rocker switch inside?
  5. Zionhill97
    Zionhill97 New Member
    Michigan
    2003 Prius
    Thinking of buying a 03 prius and it has symptons of it will start and move but it a top speed of 20 mph! Is the main battery failing and it does not have enough electricity to go any faster? Need help! Thanks
  6. bisco
    49,504
    welcome! do any warning lights come on?
  7. Zionhill97
    Michigan
    2003 Prius
    No none Does the car only able to drive to a speed of 20 mph tell you anything?
  8. Zionhill97
    Michigan
    2003 Prius
    If main battery is failing, is that a symptom? It will start and back up but not drive very fast!
  9. bisco
    49,504
    there are a few possibilities. it sounds like the engine isn't starting. what is the battery indicator reading?
  10. bisco
    49,504
    how many miles on her?
  11. Zionhill97
    Michigan
    2003 Prius
    270,000 miles Im not at the car at the moment
  12. Zionhill97
    Michigan
    2003 Prius
    I am a newbie Haha!
  13. Zionhill97
    Michigan
    2003 Prius
    If voltage is not close to 14.4V then engine will not start?
  14. dolj
    dolj Senior Member
    7,659
    3,877
    Wellington, New Zealand
    No totally not true.
    The 12 V supply os only for booting the car, once in READY, it uses power from the main battery to turn over the engine.
    If you have no experience working on these cars, you should probably steer clear of this car.
    And on an editorial note, please don't tack on to other people's threads, please start your own, you will get a better response that way and not confuse the OP's (original poster's) thread.
    Also, you should be posting on the Gen I forum, this is the Gen II forum.
