Help me achieve the 51 city that Toyota advertises
Discussion in 'Gen 3 Prius Fuel Economy' started by d2mini, May 5, 2012.
  1. d2mini
    d2mini Active Member
    519
    106
    Houston
    Seriously... I'm trying to figure out how in the world you get 51mpg in city driving. :confused: Toyota rates the prius as 51/48, which to me is the complete opposite of the results I'm getting. On the freeway, I can pretty easily achieve in the mid 50's, doing around 65mph. High 50's to low 60's in heavy commuting traffic where I can coast a lot or use electric only at very low speeds. But either my definition of "city" is different than their's, or I'm doing something seriously wrong. To me, city driving is stoplights every couple blocks and lots of accelerating from complete stops. I would also assume that Toyota's numbers are based on regular driving, not any kind of hypermiling, especially with their conservative hwy number. I drive pretty calmly in the prius, and accelerate from a stop just fast enough to not completely P.O. the people behind me. My HSI screen usually shows acceleration in the second half of the bar and I try to keep it out of the power section at the end. I know you can hypermile it and keep it in the low eco section, but in normal day to day driving that tends to be impractical and can even be somewhat dangerous. Especially when pulling out of driveways or side streets on to busier/faster roadways. So how does toyota expect the average driver to achieve such a number? In short drives of like 2-5 miles, even with a warmed up car, I get around 25-30mpg in TRUE city driving. If I'm just cruising through the neighborhood on back roads with no traffic, then I can achieve in the 40's. But not in the busy city areas. And remember, I'm in Houston... the 4th largest city in the country, and one of the warmest too so the A/C is always on. And I have the 17" wheels. I know that doesn't help. So what gives? Help me out please! :)
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    The EPA cycle is NOT even close to Houston standards of driving. ;)
    You pretty much answer your own question with all your qualifiers and examples.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It is not a Toyota number, it is an EPA number. The EPA city test does not involve a cold start, the engine is already warm and the Battery is charged up. It mimics a very slow drive in a section of downtown LA in the 1970's.
    Assumptions about what Toyota might so are not relevant, all they can do is follow the precise EPA rules. In the US, you MUST show EPA numbers in a larger font than any other mileage numbers you may wish to show.
    2 people like this.
  4. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    CITY means NOT HIGHWAY.
    It really is that simple.
    SUBURB should be a seperate category. In fact, there is a third in the UK to clarify the very situation you've been struggling with. Unfortunately, our EPA here leaves the opportunity for that particular misunderstanding wide open still.
    The "city" you are thinking is the least efficient type of driving... even for a plug-in. All that accelerating from a stop is quite wasteful.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    your assumptions are all wrong
    Please read http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html.
    The test was devised by the EPA, not Toyota. Throw out your assumptions about Toyota's numbers. The test results listed on http://www.fueleconomy.gov/feg/sbs.htm and the Monroney (window) sticker likely were conducted and self-reported by the automaker itself, but all according to the EPA test procedure. The EPA does test some cars themselves to verify those results. I'd imagine that given the Prius' high ratings, the EPA re-tested it.
    Hints: The EPA test is conducted on a dyno, not a real road. The only tests started w/a cold engine are 31.2 minutes long. The city drive cycle is 11 miles long (and starts from a cold engine). AC is turned off on all but one cycle. The EPA test doesn't even measure actual fuel usage, but rather tailpipe emissions. The highest average speed of ANY of the test cycles is 48.4 mph.
    Please read the above URL for more details.
    As for Toyota and "expecting" the average driver to achieve such a number. There is no expectation. Supposedly, all automakers are legally required report and advertise to the only (?) the EPA numbers, although I've seen VW try to skirt the system before in some ads for their diesels (http://priuschat.com/forums/other-c...di-ad-advertising-non-epa-method-mileage.html).
  6. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    210
    San Diego, California
    Thanks- the engine is already warm. That makes a big difference.
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    As John stated above, stop and go driving is very wasteful. It takes a lot of energy to move a Prius. Because rolling resistance plays a large part in fuel efficiency at low speed, those heavy 17" wheels will hurt mpg much more in stop and go driving than at sustained highway speeds.
    I also find it difficult to achieve great city mpg unless the route allows me to glide between stop signs/lights. In some areas this is easy to achieve and in others it is not possible. This is why EPA always states "your mileage may vary". They simply cannot reproduce every driving condition, scenario or vehicle trim level. Keep in mind that the EPA rating was set for the Prius with 15" wheels, not 17s.
    I would suggest you try to accelerate a little more briskly. Get up to your desired speed the lift off the throttle completely. Gently reapply just enough pressure to maintain your desired speed. Then anticipate your next stop and start gliding as soon as possible.
    Accelerating briskly is more like normal driving and less like hypermiling so driving should be more enjoyable. ;)
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I just noticed you are using the AC on those short trips too. That is a recipe for low mpg if you have the AC blasting and have many stops on your route. I would start paying attention to how often your engine shuts down at a stop with the AC on. Then try turning the AC off and driving with the windows down and see if the engine shuts down more often. The engine will usually run more often when the AC is on and running hard. This will definitely drop mpg in a hybrid.
  9. fuzzy1
    10,159
    The very first time I experienced Texas city traffic was hours after witnessing an icy spinout just barely in front of my own car in Spokane. My first thought: These Dallas drivers would be in extreme trouble in any sort of snow or icing conditions.
    The next day, one of my interviewers was a Minnesota native. He confirmed my feelings with his story of his first Texas snow day. He noticed that the roads were nearly empty of cars, the ditches were not empty of cars, but only after reaching work and finding the doors locked did he think to turn on the radio. Only then did he discovered that the city had shut down.
    Driving styles display drastic regional variations. Watching traffic behavior the few times I've visited, I'm not the least bit surprised that common Texans have difficulty achieving EPA numbers, even when it is cool enough to turn off the AC.
  10. litesong
    litesong Active Member
    371
    122
    Everett, WA
    ethanol-free gasoline for better mpg
    Many places offer gas saving tips. One tip not mentioned often, is NOT to use 10% ethanol blend gasoline, but only 100% ethanol-free gasoline. Go to pure-gas.org for addresses & a great zoomable map showing the minority of 5150 stations selling 100% ethanol-free gasoline. However, most large cities have severe restrictions by the EPA for selling 100% ethanol-free gasoline AND Houston is one of the worst. From the map at pure-gas.org showing stations selling 100% pure gas, Houston(& other cities) has a big region around them selling no 100% ethanol-free gasoline.
    You might try local marinas, airports & farm co-ops(who may have 100% ethanol-free gas & have exemptions from the EPA) to see if you could buy their 100% ethanol-free gasoline, but that might be a tough row to hoe.
  11. Much More Better
    Much More Better Active Member
    655
    163
    Like you I have the 17". I keep my tire pressure at 42/40 front/rear. My drives are usually at least 7.5miles or 20mins long to work. Where I live we have no freeways. I never take my car on highways so I rarely clock over 60mph. So my avg speed per tank is about 22mph. I accelerate with the HSI just into the PWR zone. I do try to pulse and glide whenever possible but not if someone is behind me. I rarely use A/C in summer and at current temps here, I don't even run the fan. I leave a crack in the window for air to circulate. Avg temp for past month is about 60F.
    Under these conditions, I got 10 consecutive 50+ mpg tanks (calculated) from May-Nov of last year.
    Short drives will kill your mpg. Even if you stop for 10min to pick up some groceries, you think it's warm, it's already cool. Running errands from groceries, Walmart, Indigo/Chapters, Home Depot, Starbucks......kills my mpgs every time.
  12. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    Take a look at your window sticker. Under where it says "51" in big bold type is a bit of fine print. It says "Expected range for most drivers 42-60 mpg." It also says that "your mileage will vary depending on how you drive and maintain your vehicle"
    I drive "normal" (no hypermiling) and average pretty much right at 50 mpg. I live in VA so my A/C is on a lot. If you are running the a/c a lot you might want to try running in eco mode, it cycles the compressor a bit less so it won't drain the battery as quick. Also as soon as I get in the car and turn it on I go. I don't wait until the engine "warms up" or the inside of the car cools off. This is just wasting gas because you are not turning it into forward momentum so your average mpg will drop.
    Also I noticed my mpg really improve after about 1000 miles. I'm not sure if that was because of the car "breaking in" or from my driving style changing. Probably a bit of both I suspect.
  13. cwerdna
    12,544
    2,123
    SF Bay Area, CA
  14. fjpod
    fjpod Member
    419
    72
    New York
    Someone already said it but anticipation is a big factor in city driving. Get your foot off the accelerator if you know you will be coming to a stop. You must anticipate other traffic getting in your way,...stop lights getting ready to change,...not accelerating into stoplights. you should drive as if your car has no brakes.
    Don't stay on the bumper of the car in front of you. At a light, start creeping forward before traffic starts moving to get a head start.
    All of this is conditions permitting, of course..
  15. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    You are getting 47 mpg combined, just shy of the EPA 50 combined on the sticker, which is pretty darned good considering the 17" wheels and lousy city traffic! It'll improve a bit as both the Prius and you get broken in, so relax and enjoy your sweet ride!;)
  16. d2mini
    519
    106
    Houston
    Thanks, guys! Lots of good info.
    At least my results seem to be normal.
    When I first started looking at a Prius, due to my new big commute (among other things) I was worried my mileage wouldn't be as good because I was driving mostly freeway and the Prius gets a better rating for city. So my results were a little unexpected.
    Like pointed out above, I still have a pretty good average. But it's like an addictive game! The Angry Birds of real life! I need that high score!!! :D
  17. Silver bullit
    608
    210
    Welcome to the club! You have discovered part of the fun of driving a Prius! The mpg game. :)
  18. NiHaoMike
    NiHaoMike Member
    98
    16
    Check your tire pressures. Actually read the tires and inflate a little below the rating. For the 44PSI tires I have, I inflate to 40PSI.
  19. d2mini
    519
    106
    Houston
    I inflated my 17's to 42 psi as soon as I got the car.
  20. Misty fog
    Misty fog Junior Member
    25
    Malaysia
    Where I live, the traffic is pretty bad as well. My daily commute consists of 8km each way. The first half consists of relatively smooth driving at average speed of 24kmph, and the second half consists of bumper-to-bumper crawl with frequent acceleration/braking at average speed of 12kmph. With a cold start, my mileage has been quite consistently around 5l/100km or 47 mpg. I estimate that the cold start probably contributed to 10% lower mileage.
    For the most part, I pay close attention to how I drive and try my best to be economical (e.g. avoid unnecessary braking etc). My worst result was around 30-35 mpg with pretty aggressive (in hurry!) driving in very heavy traffic.
