Help me pick tires for my F150...haha
Discussion in 'Gen 3 Prius Main Forum' started by kehyler, Dec 17, 2018.
  1. kehyler
    kehyler Member
    84
    32
    blah
    Hi All,
    I am curious for peoples opinions on eventually replacing my F150s tires with either Michelin energy saver 235/80 R17 A/S or the Michelin Defender LTX 265/70 R17 M/S. My priorities are first fuel efficiency, and then second ice, and then third snow. (Both tires can be had in load range E. The energy saver is essentially the same size, although 1 inch narrower.)
    https://tiresize.com/tires/Michelin/Energy-Saver-AS-235-80R17.htm
    https://tiresize.com/tires/Michelin/Defender-LTX-MS-265-70R17.htm
    Thanks as always,
    -kehyler
    52,015
    great tires, but hard to know how well they will work to save gas on a truck. does tire rack review them?
  3. kehyler
    kehyler Member
    84
    32
    blah
    I had been assuming that LRR tires would help on a truck too...at the moment, I'm looking primarily for mainly a LLR tire that has a small amount of snow/ice life to it.
  4. Usle
    Usle Active Member
    317
    140
    Me
    2018 Prius Prime
    Get the defender, it's a mud and snow tire with a much longer tread life, haven't looked at your size, didn't know they made hugh LRR tires, but go to tire wrack and look at the specs for both tires, the Defender is superior.
  5. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    IMO, I look at this like buying a diet coke to wash down a supersized double whopper with extra cheese and fries, but to each their own.
    I have a Superduty F250, which is a gas pig. So I only drive it when I need it, and it wears heavy-duty work tires with aggressive tread. I know the tires will get me thru any condition, and live with the down side of its thirst for fuel.
    On a side note, I'll be interested to see Tesla's pickup when it becomes available.
    The Electric Me and jerrymildred like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    @KennyGS has a point. I wouldn't expect much, if any, visible improvement in fuel economy. The tires on a truck account for a much smaller percentage of the fuel used than on a lightweight, aerodynamically clean Prius.
    Pluggo likes this.
  7. Mendel Leisk
    41,545
    It's somewhat apples/oranges, since the defenders are so much wider. The Defenders used to have the GreenX label, not sure if they still do, or if anything has actually changed, say in its rubber formulation. They're a decent all-round choice.
  8. kehyler
    kehyler Member
    84
    32
    blah
    I think they are both reviewed well, I'm more just curious about how to maximize mpg.
  9. kehyler
    kehyler Member
    84
    32
    blah
    My primary concern is to maximize mpg though?
  10. kehyler
    kehyler Member
    84
    32
    blah
    True, but a pig with a lipstick still looks better than a pig without lipstick. (Small choices matter, albeit lesser, than big ones.)
  11. kehyler
    kehyler Member
    84
    32
    blah
    What would you guys think of doing a slightly smaller/slightly narrower tire to increase mpg?
  12. bisco
    52,015
    i have an '05 dakota, 18 mpg no matter what i do. but the tires are huge. will narrower tires carry the same weight?
    #12 bisco, Dec 20, 2018
    KennyGS and Raytheeagle like this.
  13. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Since the weight of the truck is the same, yes:p.
    But how well it carries it is a good question ;).
  14. Mendel Leisk
    41,545
    Better clarify "slightly smaller". If you mean reduced outside diameter (more than trivial amounts, say limit of 2%), then it gets complicated: you're changing gearing, and throwing the odo off.
    I would try to keep outside diameter as close as practical, and then yeah: a taller/narrower tire should reduce rolling resistance.
  15. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Why have a F150 in the first place? If you are concerned about MPG get a fuel efficient car. The savings at the gas pump will probably pay to rent a truck when you really need one.
    KennyGS likes this.
  16. KennyGS
    1,243
    1,044
    Keystone State
    No lipstick needed for my truck, thanks.
  17. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Looks like the back ventshade could use a little love:p.
  18. KennyGS
    1,243
    1,044
    Keystone State
    Yeah, took a hit on the last snow/ice. :( Oh well, an easy fix come spring. (y) It made it for 20 years.
    Mendel Leisk and Raytheeagle like this.
