Help me please! My 2009 toyota Prius is the closest near death experience rollercoaster I have eve.
Discussion in 'Gen 2 Prius Main Forum' started by charesa beall, Jul 18, 2020.
  1. charesa beall
    charesa beall New Member
    Oahu
    I first experienced this going driving on the freeway going about 60mph a ringing sound came on my steering wheel locked up an I couldnt brake it went straight in neutral on its own anybody experience this what to do???
  2. charesa beall
    Oahu
    I pay 370 every month an I can even drive more then 10 miles it keeps doing this thing
  3. SFO
    SFO Senior Member
    5,302
    4,247
    Northern California
    Welcome to PriusChat!!
    Happen to have any OBD2 codes (DTCs) that you could share with us here?
    It sounds like you had some type of brake failure.
    You can check the dealer service history by running the VIN at Welcome to Toyota Owners
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    And you actually drove it AGAIN after that happened ???
    I hope your insurance is paid up.
    You should NOT drive it any more until this gets fixed.......or where you bought it lets you trade it for a different car that is not
    a DEATH TRAP.
    I think Toyota needs to hear about this.
    And maybe the Federal safety agencies too.
    charesa beall likes this.
  5. bisco
    51,748
    how many miles on her?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    that’s pretty nutty even nuttier your still driving it.
    So your saying you hear ringing sound from steering wheel then the steering wheel locks up then you have no brakes how is it you didnt crash?
    How did the you get the car back home and then it just fixes itself.
    If this happened it would throw lots of codes (warning lights) on the dash codes The dealer can pull to diagnosis the cars issues.
    There was a steering TSB out for the G2 that included replacement of the intermediate steering shaft that was 10 years ago.
    Go to Toyota.com/ owners forum and join it will ask you for the cars vin have your insurance card handy. You will then be able to see all TSBs performed on the car plus any parts replaced on the car at any authorized Toyota dealer repair centers it’s lifetime.
    See if it mentions that steering TSB.
    It does for my car on that forum.
    And stop driving it.
  7. charesa beall
    Oahu
    I bought it from a ford dealership an they would not let me trade it in since its not even been 1 year having paid of half so far there real assholes.
    62,000
    #7 charesa beall, Jul 30, 2020
  8. charesa beall
    Oahu
    Finally got my appointment with toyota
    Droped of my car yesturday they called me an told me this was the problem
    Charesa
    Update on your Prius. During inspection technician Found the following:1. Inverter Water pump failing due to open circuit
    2. ABS Actuator failing due to open circuit
    3. Air Fuel sensor has a short
    4. 12v Battery has low voltage
    I will contact your Extended Service Contract which you purchase from Honolulu Ford to verirfy repair coverages then I will update you later today on the status.
    Thanks, Jhanelle @ Servco Auto Waipahu 564-2053
    #8 charesa beall, Jul 30, 2020
    SFO likes this.
  9. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Has does any of that lock up your steering wheel?
    Those are all very very common failures on a g2 Prius.
    That abs actuator failure is very very expensive the inverter pump at the dealer is 500-700
    Needs a new 12 volt battery I would bet you jumped it a few times so no surprise there that’s 300
    Air fuel sensor not sure maybe 200 the abs will be $2500 to $3500.
  10. charesa beall
    Oahu
    Yes they replaced the abs covers on warranty my warrenty. Paid 3000 for 1 year.
    One main repair that cost more was the inverter water pump that's under the hybrid system not electrical components?
    I'm so upset my car had the best a.c. when I picked it up from the toyota service department after 2 long weeks it has no a.c.
    #10 charesa beall, Aug 22, 2020
  11. charesa beall
    Oahu
    My mind is blown took my. As for service with ac picked it up blowing both air shouldnt it be there fault an have to fix this???
