Help! - MPG # will not change
Discussion in 'Prius c Main Forum' started by CA Moonglow, Sep 12, 2013.
  1. CA Moonglow
    CA Moonglow New Member
    Los Angeles
    Today when I was driving to work I noticed that my MPG calculator didn't now change. It stayed at 48.6 through my 30 minute drive to work. I though it was a glitch and would go back to normal. I was driving back home and it stayed and 48.6, it didn't change whatsoever. Has this happened to anyone else? Should I take it to the dealership?
  2. CraigB
    CraigB Member
    205
    96
    SF Bay Area, CA
    This has happened to me twice over one year span. It went back to normal on both occassions after I refilled the gas. I don't know why but the gas refill worked.
  3. CraigB
    CraigB Member
    205
    96
    SF Bay Area, CA
    By the way...mine was stuck at 48.6 as we'll.
  4. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    Are you sure you're on ODO, and not on one of the Trip meters? My Trip B, for example, has tracked my average mpg for the life of the car. It certainly wouldn't change on any single commute (in fact, it hasn't change in months). Press the Trip button to cycle through ODO, Trip A, and Trip B.
    minkus, Erinmarie424, Rob.au and 3 others like this.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    ^ my first thought as well.
    Erinmarie424 and Rob.au like this.
  6. mahout
    mahout Active Member
    655
    116
    NC
    Remember the mpg indication is the mpg overall SINCE YOUR trip odometer was reset. If yo have never rest it and it has a few thousand miles since restting it will require a dramatic change in actual instantaneous mpg. And you can't zero reset the total mileage.
    Try resetting it on the steering wheel for one or both trip registers and check mpg for changes; there will be a dratatic change but wait til it gets out 10 miles or more before believing it.
    minkus likes this.
