Help! My 2004 prius is having issues: Brakes and Pack Battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Seth A. Hargis, Aug 12, 2023.
  1. Seth A. Hargis
    Seth A. Hargis New Member
    Knoxville, TN
    Hello everyone, I am going to try and jump straight to the point. The other day, went to drive my prius and when I went to back up, the brakes hardly worked and the pedal was not sensitive and hardly worked as well. My car also was running and trying to charge the battery at a high rate, and could not keep the charge on the battery. I ran a scanner and it produced a few codes-P3015, P0A80. I found these relate to the Pack battery, so being a college student and not able to afford a new battery, I decided to take everything out and test the volts in each module. I found that 1 of my modules, #9, was running at 6.7 instead of 7.9. I replaced it, now runs at 7.9. After turning my car back on, the brakes are still not functioning at all. Now is running code P3056 since i changed the module. Any tips on anything? not really sure what the breaks are doing. All the brake error lights are on, and the emergency brake light as well, even though it is not engaged.
    I have pictures if someone is interested.
    Thanks everyone,
    Seth
    52,862
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    What are you using to check codes? You might need something more capable to "talk" to all the systems on a Gen2 Prius.
    Here's a thread that reviews several scantool apps and devices.
    https://priuschat.com/index.php?posts/3290690
    P3056 is for the HV battery current sensor. It's the white plastic ring that the big orange negative HV battery cable goes through - near the contactor relays. You want to make sure you plugged the little 3-wire connector into the sensor and the other end into the ecu (& that none of the wiring is damaged).
