Help! My right leg and foot go numb
Discussion in 'Gen 3 Prius Main Forum' started by southjerseycraig, Jan 18, 2010.
  1. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    When I drive my Prius for longer than about 30 minutes, my right foot and my leg, up into the thigh, become numb. This is not only annoying, but also a safety concern because my feel for the accelerator and brake is diminished.
    Is this an issue with the seat? (I notice the seat extends pretty far down my thighs). Is there some way to resolve the problem by adjusting the seat? Or are there other causes for and solutions to this problem.
  2. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    I'd try lowering it a little first. If that's no help raise it a little.
    Not sure if either will help but worth a try.
  3. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    If nothing helps, see a doctor at once as this could be a sign of a bigger problem.
  4. ibmindless
    ibmindless Member
    206
    Take your big fat wallet out of your right rear pocket! Seriously - my big fat wallet caused that sort of problem.
  5. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
  6. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    hmm, I thought everyone's wallet was quite a bit thinner after taking delivery of their new car from their dealer....
    Actually, some good input here. I found that I needed more thigh support from the seat as the support was poor for me. I lifted the front of the driver's seat mounts to tilt the front lower cushion up about 1/2". That bit of extra "tilt" made a huge difference.
  7. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    I've had a similar problem in the past with my Previa and in other cars without sufficient thigh support for my long legs.
    I just finished a 5500 km trip in our 2010 Prius with no problems. I believe that it is the extra leg room and adjustable height/slope of the drivers seat base that saved the day. I would have preferred a bit more lumbar support but the lack of it did not cause a problem.
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    As far as support is concerned, the OP is stating that the seat goes *farther* down his thigh than most seats. This is not indicative of too little support, but perhaps support at the wrong angle, or a pressure point.
    I'd start by adjusting the seat position.
    Tom
  9. bad1550
    bad1550 New Member
    29
    NY
    Can anyone suggest adding a lumbar support?
    On long trips it will help since I have a herniated disk and would require better support. The IV was out of my price range which included lumbar.
    Bob
  10. F512M
    F512M Member
    415
    Laguna
    +1, I would still have it checked
  11. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Ok, but if the 2010 has a vertical rear mount bolt like the 'Gen2' left rear, seems like a mount foot could get bent from doing this. And that could get really expensive ... to fix. Some say, just loosen the mount bolt. O. K. But doesn't seem smart to just loosen a mount bolt when they are to be torqued to about 27 lb-ft.
    The 2010 seat bottom makes a lot of tilt with the height adjuster full down. Strange it would need more.
    A flattish seat bottom is an 04 - 09 Prius driver's seat. But one would never know it when 5'4" or SLT.
  12. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Like others have said, adjust the seat. Seems like you may have tried that already. Then get to a doctor.
  13. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
