Help! Need an experienced audio tech in Bucks County,PA...
Discussion in 'Gen 2 Prius Audio and Electronics' started by BubbaVO, Aug 25, 2009.
  1. BubbaVO
    BubbaVO New Member
    53
    Philly
    I've been sending it to the same guys for over a year. And they still haven't figured out how to install my system without draining the 12v battery. Oddly enough, I've seen them work on Ferraris and Bentleys. But they just can't seem to figure it out for my Prius.
    I need someone who can figure out my little system - an amp/powered subwoofer. I don't have the inclination to tear apart my car to do it myself. Any recommended techs? The closer to the Doylestown Township - the better.
    Thanks.
  2. jdenenberg
    jdenenberg EE Professor
    3,837
    1,827
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Just have the tech provide the power to the amp via a relay Like one used for fog lights or a starter in a std car) that only activates when your Prius is in "ready" mode.
    JeffD
  3. BubbaVO
    BubbaVO New Member
    53
    Philly
    These guys are so arrogant that they refuse to implement those suggestions. They act like they know better because...they just do. That's why I'm looking for an alternative.
  4. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    Here is how I connected mine.
    12v+ (red wire) directly to the positive terminal of the 12v battery
    Negative ground (Black wire) directly to the negative terminal of the 12v battery
    Remote turn on wire I connected directly to the fuse box (underneath the drivers side dash) and I connected it to either the fuse for the rear wiper or rear defrost, I can't remember. Either way the amp will now only power on if the car is in Ready or Accessory. I hope this helps.
  5. BubbaVO
    BubbaVO New Member
    53
    Philly
    Maybe that will help in communicating what needs to be done. Thanks.
  6. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Here's the wire color chart for a 2G Prius.
    Car Radio Battery Constant 12v+ Wire: Light Blue
    Car Radio Accessory Switched 12v+ Wire: Gray
    Car Radio Ground Wire: Brown
    Car Radio Illumination Wire: Green
    Car Stereo Dimmer Wire: N/A
    Car Stereo Antenna Trigger Wire: Orange
    Car Stereo Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Speakers Size: N/A
    Car Audio Front Speakers Location: N/A
    Left Front Speaker Positive Wire (+): Pink
    Left Front Speaker Negative Wire (-): Violet
    Right Front Speaker Positive Wire (+): Light Green
    Right Front Speaker Negative Wire (-): Blue
    Car Audio Rear Speakers Size: N/A
    Car Audio Rear Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Black
    Left Rear Speaker Negative Wire (-): Yellow
    Right Rear Speaker Positive Wire (+): Red
    Right Rear Speaker Negative Wire (-): White
    I wired mine in like this:
    Positive to positive on my battery. Ground to the body.
    Then for the acc wire (which is a gray wire) I spliced into it on the amp under the seat, for my amp to turn on and off with the car.
    I have the JBL system, not sure if you do though.
    I also put a cap in....just incase.
    btw, you can also run a wire from the positive and acc in, to the front seat with a switch. Then you can turn it on and off when you want.
  7. BubbaVO
    BubbaVO New Member
    53
    Philly
    No JBL in this one.
    Sorry to be such a noob, but what is an acc wire?
    What kind of parts do you need to put a manual switch on to the remote turn on wire?
    Would that be just as effective as moving the connection of the remote wire from the radio to the rear defogger in the fuse box?
  8. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    Wow... don't use the rear defogger as a remote turn on. A good spot to pull the ACC (remote turn-on) signal is from the center console 12 volt port. The center console can be removed by taking out the screws from the bottom of the console interior. They're covered by a mat.
  9. BubbaVO
    BubbaVO New Member
    53
    Philly
    Why is that a bad idea?
  10. Presto
    1,326
    24
    Vancouver, BC
    Besides being a duct-tape sort of solution, it's also kinda Mickey Mouse to have to turn on the rear defog to turn on the stereo system. If the window isn't foggy, it's also a waste of power. Let the power state of the car (ACC) control the power to the stereo. You can put a switch on wire, since there isn't much current going through it, if you want semi-manual power control.
  11. Prius 06
    Prius 06 Member
    283
    29
    Ontario, Canada
    Acc wire is the accessory wire. It only receives power when the ignition is turned on. Which is what you'd want. From the sounds of it the car is currently wired so that the amp always receives power, which is what is draining the battery.
    If you wired it off the acc wire, then the amp will only turn on when the car is turned on.
    As for putting a manual switch on, you'd just need to run a wire from the constant power on your amp to the front seat, put a switch in, then run the wire back to the acc/remote on the amp.
    I'm willing to bet that the way the amp is currently set up, they've got a wire running from the constant to the acc/remote...which would keep it on all the time.
    Maybe you could take a pic of your amp?
    This way we can see how they've got it set up.
