Help!! Need plastic part under fender.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Luv07Prius, Nov 11, 2009.
  1. Luv07Prius
    Luv07Prius New Member
    Southeast Los Angeles County
    I accidentally ran into something on the freeway and the plastic piece that goes under the right fender (above the tire protective plastic) came loose and I had to cut it off. Now I need to find that piece to replace it. My baby is a 2007 Prius, I'm afraid to drive it around without that because parts of the engine are exposed. I need help finding that part around the Los Angeles area!! Thanks!!
  2. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    I can't help with a local supplier in LA. I'm not even sure I've been able
    to identify the part you need on the 'net.
    FWIW, Here's a link to an exploded-view parts breakdown of the front
    fender:
    Wholesale Toyota Parts
    Hope this helps.
  3. Luv07Prius
    This website helped alot!! Thanks!!
