Help Need to replace Both Stablizer links,Best brand?
Discussion in 'Gen 2 Prius Main Forum' started by deejay, Sep 2, 2021.
  1. deejay
    deejay New Member
    nj
    I have a 2009 Toyota Prius touring.i took it too the mechanic a year ago and let him put what ever stabilizer link he wanted and it wore out in a year :(
    i would like to buy the stabilizer links and get a it installed.
    please do recommend what stabilizer links i should use.i would like long lasting ones
    Thank you!
    SFO likes this.
  2. Rph74
    Rph74 Active Member
    292
    234
    Springfield,MO
    5 years/100k on my Oreilly’s stabilizer bar links and all is still good. Lifetime warranty so I’ll never have to buy them again. If you don’t DIY, it’s probably going to be hard to beat OEM for overall quality.
    DIY isn’t bad, I did this write up back in 2016:
    Gen II Stabilizer Bar Link DIY | PriusChat
    deejay likes this.
  3. Eyelawdoc
    Eyelawdoc Junior Member
    Palmdale, CA
    I'd recommend Moog stabilizer end links, part number K80230. Not only are they a quality part, they include zerk fittings so you can grease the bushings at both ends of the link.
    They are a bit pricey, even Rock Auto gets $24.79 each for them. You will need two, one for each side. However, they should easily last the life of the car!
    deejay likes this.
  4. douglasjre
    douglasjre Senior Member
    2,205
    736
    Null, NL
    Rock Auto
    deejay likes this.
  5. deejay
    deejay New Member
    nj
    Thanks soooo much for your reply,Much appreciated
