help needed! just got rear-ended hatchdoor wont close
Discussion in 'Gen 2 Prius Main Forum' started by JCPrius, Jul 28, 2021.
  1. JCPrius
    JCPrius Junior Member
    Just got rear-ended on a local road. Took a pretty hard hit and left a big dent on rear bumper. Hatchback door also got damaged and wont close now. I am going to take my Prius to the shop tomorrow. Since the door wont close, the door open warning light is lit from the dashboard. Is there anything I can do to prevent from a battery drain?
  2. privilege
    privilege Active Member
    659
    169
    Birmingham
    disconnect the battery
    SFO likes this.
  3. Leadfoot J. McCoalroller
    8,147
    7,649
    Pennsylvania
    2018 Prius c
    Get a 7mm carabiner and click it into the latch mechanism. You can also use that as a tie-off to physically hold the lid down.
    Another likes this.
  4. Mendel Leisk
    41,905
    I did this (when carrying a long load, on our 3rd gen) and it didn’t stop the beep; did work as a hold down point though. Regarding not silencing the beep: maybe wasn’t quite the right shape??
    SFO likes this.
  5. ChapmanF
    18,547
    The latch (like most automotive door/hatch latches, for maybe some standard safety reason?) has two levels of click.
    It has to be latched to the second click to make the hatch-ajar switch.
