HELP! No dash lights and won't shut off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by exmetrodriver, Jan 14, 2015.
  1. exmetrodriver
    exmetrodriver Member
    124
    16
    Puget sound, Wa.
    This has happened today to me. I had read a couple "old" posts about people experiencing the same issue. Does anyone know if this was pinpointed to a cause? I will test the 12V after work. I just replaced that 4 months ago. Any help would be greatly appreciated.
    52,386
    i think this might be the classic defective mfd.
  3. exmetrodriver
    124
    16
    Puget sound, Wa.
    What is this part?
    52,386
    multi function display. the touchscreen with all the controls. there're many threads on it and enough defective units that toyota had a 10 year extended warranty. it has been traced to a bad solder joint on the pc board, but has proven unrepairable. best bet is ebay or a junk yard dog.
  5. exmetrodriver
    124
    16
    Puget sound, Wa.
    The MFD is working. I'm not getting my MPG readings on the MFD. The speedometer display and all the other bells and whistles associated with it or not working.
  6. valde3
    valde3 Senior Member
    2,002
    750
    Finland
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    My post #10 below, contains two post to Luscious Garage regarding the Combinaton meter problem. Read both to become better educated about the problem. Print the Toyota notice regarding the 10 year extended warranty on this part (link provided by Luscious). This notice will give you ammunition to push back on a dealer, should this problem not be occurring in their presence.
    Need serious troubleshooting help.... display / shut off issue | PriusChat
    Hopefully your car was purchased sometime in 2005 (expires in 2015) vs 2004 (expires in 2014).
    EDIT: Combo meter warranty extension is 9 years. Unfortunately, you are probably out of the extended warranty coverage given your model year (2005 + 9 = 2014)..
    #7 exstudent, Jan 14, 2015
  8. bisco
    52,386
    the mfd controls the features you are finding defective.
  9. alekska
    alekska Active Member
    435
    138
    Atl
    To shut down the car press and hold for 10 seconds the Power button.
    - Alex
  10. northwichita
    481
    102
    29
    Wichita KS
    Holding down the power button 10 seconds normally works, but I've had a defective combination meter ignore that, I disconnected the negative ground to shut off the car totally.
  11. exmetrodriver
    124
    16
    Puget sound, Wa.
    So when I left work today all was good. So Toyota will take care of the MFD even if the car is 1o years old?
  12. exstudent
    2,214
    905
    Torrance, CA
    You are confusing Combination Meter and Multi Function Display (MFD).
    Combo Meter = speedometer and gear indicator (P, R, N, D/B)
    MFD = big touch LCD screen that shows battery charge status, avg MPG, amount of regeneration, radio station presets, etc.​
    10 years was a mistake.
    NINE years is the extended warranty coverage Toyota has been providing for combination meters in 2004-2009 model year Prius.
    Assuming your 2005 model year was purchased in 2004 or 2005, you are outside of warranty coverage:
    2004 + 9years = 2013
    2005 + 9 years= 2014​
    You can always call Toyota Customer Care (you can Internet search this number or look in your owners/warranty manual), and beg/plead for any assistance.
    You should still open the link in my post #7 above, to learn more about the Combination Meter Problem. The link above provides links to two articles by Luscious that explain the problem well and repair strategies they tired. As you experienced now, the combo meter problem is intermittent. However, you are guaranteed that the intermittent frequency will become steady and reliable.
    #12 exstudent, Jan 15, 2015
  13. exmetrodriver
    124
    16
    Puget sound, Wa.
    Thanks for the info. I think my 2005 was built in 12/05 so it may still be within the 9 years.
  14. exstudent
    2,214
    905
    Torrance, CA
    Warranties are based on purchase date. Your purchase date + 9years = expiration date.
    EDIT: Warranty clock start from first purchase date. If you are second owner, when did original owner, originally buy the car? This becomes the start date, not your purchase date, if you bought the Prius used.
    #14 exstudent, Jan 15, 2015
  15. GregP507
    GregP507 Senior Member
    3,002
    481
    Check to see if a door's not latched.
  16. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I found this on YouTube.com
    It has this headline.
    Fix - No speedometer dash lights toyota prius power won't turn off Combination meter- 07 prius
    He said that the battery was low. Maybe not, comments said they had a new battery and still had the problem. Then he said to take the heads up display to a Toyota dealer.
    Does this only reset the display? I think that this is so. I will still have to see if my dealer will exchange it with a good one, extended warranty.
    #16 CrazyLee, Jan 16, 2015
  17. GregP507
    3,002
    481
    This wouldn't happen if you use ready-mode instead of acc-mode.
    By the way, one-handed videos are a torment to the viewers.
  18. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I am sure I used ready mode (IG-ON) and didn't get a display.
    Yeah, those guys don't have a clue of how to run a camera! U Tube has the biggest bunch of clowns you have ever seen.
  19. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
    READY mode is not IG-ON, they are two separate states. IG-ON is achieved by pressing the START button twice with your foot OFF the brake pedal; while READY mode is achieved by one press of the START button with your foot ON the brake pedal.
    #19 dolj, Jan 17, 2015
  20. exmetrodriver
    124
    16
    Puget sound, Wa.
    Well I have had no issues since. I took at look at the online record on Toyota's site and the previous owner had the same issue 30,000 miles back at 108K .
