Help: One quart of oil every 1000 miles
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by phueber, Nov 29, 2010.
  1. phueber
    phueber New Member
    New Hampshire
    Anybody have any idea steps my mechanic should take to solve the problem of using a 1uart of oil every 1000 miles. Problem has gotten progressively worse. 2007 has 181,000 miles on it. Thanks.
  2. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    One quart of oil consumption every 1000 miles is considered basically normal by most manufacturers. If you were under warranty they would likely not address it unless it was worse than that. I know my Prius with 155k uses about 1 every 5k, but it varies from engine to engine. Your mechanic could check the PCV system, but assuming there are no external leaks, I wouldn't worry about it unless it gets worse.
  3. Patrick Wong
    18,200
    6,479
    Especially considering the odometer reading, this would be deemed normal.
    If you really wish to solve the problem you would need to have a salvage engine installed, which might cost $500 for the engine and $700 for labor. It's more economical to continue adding a quart of oil periodically.
  4. Mr.Vanvandenburg
    1,097
    386
    2020 Prius Prime
    Check for oil leaks, seems obvious but overlooked. Do a compression/leakdown test. Look for blue smoke on startup, under acceleration, and after coasting then accelerating (valve stem seals.) Too long oil change intervals for the conditions would be my guess for piston ring wear. People who are diligent about oil changes and those who are not, makes all the difference at near 200k IMO. That's a lot of driving on an 07, a lot of life spent behind the wheel.
  5. uart
    uart Senior Member
    4,215
    1,201
    Australia
    What type of oil are you using phueber?
    You could try a high mileage oil. I'd recommend trying Valvoline Maxlife 5W30 synthetic blend. It's designed for high mileage engines that consume a bit of oil and seems to work pretty well.
