Help! Piece hanging off near right, back tire. Maintenance and troubleshooting
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nikkohdeleon, Aug 20, 2015.
  1. nikkohdeleon
    nikkohdeleon New Member
    san Diego
    I have a 2010 Toyota Prius and this morning while looking at my car from far away I found this piece hanging. image.jpg Can someone help me find out what it is and how I can resolve it. Thanks
  2. Mendel Leisk
    41,486
    Yipe! Headlight levelling bracket, come loose. If the bolts are still on it you can swing it back up, reattach to underside.
  3. nikkohdeleon
    san Diego
    Where do you reattach it to??
  4. Mendel Leisk
    41,486
    Swings back up and bolts hold it to nuts welded to car body. Pretty sure they're M6 coarse thread (10 mm socket size).
    Those don't just come loose: someone been under recently??
    Without jacking up its hard to get a good pic. Here's what I'm seeing, and I have the same LED headlights with the levelling system:
    I can see at least one bolt in your pic, you may be in luck. You can get bolts at Home Depot, for one. There's coarse and fine thread M6, they're typically coarse. If you're missing one.
    #4 Mendel Leisk, Aug 20, 2015
  5. nikkohdeleon
    san Diego
    Thanks for all this help. I just looked underneath and the welded piece is broken so while I have the bolts and everything still, it has nothing to attached to. Any suggestions? Should I be concerned?
  6. Mendel Leisk
    41,486
    I think you're saying that the captured nuts in the car body are damaged? In this zone:
  7. nikkohdeleon
    san Diego
  8. Mendel Leisk
    41,486
    New parts might be needed. Must have bottomed out.
  9. Mendel Leisk
    41,486
    You could jury rig a wire link for interim, till part comes. No warning lights. ?
  10. nikkohdeleon
    san Diego
    No warning lights at all
  11. Mendel Leisk
    41,486
    Better pics of mine. I wonder if Canadian model is different, the linkage looks more lightweight.
  12. nikkohdeleon
    san Diego
    It's this zone. The metal broke. I'm thinking the best thing to do is re weld it.
  13. Mendel Leisk
    41,486
    Yup, at that bracket: weld and repaint the area. Are you lowered? Musta snagged on something?
    Keep it assembled, at least for the first tack weld, to make sure you get alignment right. There should be weld remnants on the cross beam too, will help relocate: a walk in the park. :)
    #13 Mendel Leisk, Aug 20, 2015
  14. nikkohdeleon
    san Diego
    It isn't lowered but I'm sure it must've snagged on something. Lol, I only noticed it after my fiancé and her girls took it on a road trip.
  15. Mendel Leisk
    41,486
