Help please !!!!! 2013 prius c overheating
Discussion in 'Prius c Main Forum' started by Briannamarie91, Apr 8, 2019.
  1. Briannamarie91
    Briannamarie91 New Member
    Lancaster ca
    Ive had my prius for about 2 years now. Bought it used with 80,00 miles. Two days ago while driving my temp warning light came on as well as check engine light. Went to auto zone got it checked they said it was a temp sensor but most likely it just needs to be reset because once coolant was added all light went off. Well driving home both lights came on again this time smoke was seeping through my air vents in the car and it shut off like if out of gas and would not cut back on. There is coolant in the overflow tank but none in the reservoir now my car wont drive. I can still cut on lights,shift, ect but it wont drive. Car currently has 156,420 miles
    #1 Briannamarie91, Apr 8, 2019
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Wait for it to cool down and see if it starts up. If it does, your water pump is probably shot and not cooling the engine any more.
    Montgomery likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    If it really was SMOKE and not steam........you have a BIG problem.
    Likely you need to have it towed to a real Prius shop.......and need to think about what your next car will be.
    Note: You got some REALLY bad advice from Auto Zone.
  4. davidc83
    davidc83 Member
    113
    50
    Scottsburg, Indiana
    2015 Prius c
    Check the thermostat first. A stuck thermostat in the closed position will cause these symptons of overheating.could also be s clogged radiator.
    SM-S327VL ?
    Montgomery and ztanos like this.
  5. Briannamarie91
    Lancaster ca
    How do i check that ?
  6. joelg1988
    joelg1988 Junior Member
    34
    32
    Las Vegas, NV
    2018 Prius c
    Most of the reasons why your C is overheating have been mentioned above, however I want to give them to you in order so you can save time (and possibly money).
    1st: The most common one is a stuck thermostat in closed position (not letting the coolant flow through the engine).
    2nd: Faulty water pump (not common in Toyotas, but it may be your case).
    3rd: A clogged radiator (sludge inside the core caused by contamination or mixing coolants types/colors).
    4th: Leaking coolant (even if it's a small leak, overtime you will lose enough coolant for your engine to not be able to have enough for a full coolant cycle). Check both upper and lower hoses and for a cracked radiator. Also check for cracked reservoir/overflow tank.
    5th: Temperature sensor (this one is very uncommon even in unreliable vehicles such as Chryslers or Mitsubishis, so it's very unlikely in a Toyota).
    6th: Clogged coolant hose. (extremely uncommon because of large diameter.)
    I hope this helps!
    #6 joelg1988, Apr 10, 2019
    Lukey51, ztanos, frenzee and 3 others like this.
  7. joelg1988
    34
    32
    Las Vegas, NV
    2018 Prius c
    Based on how the thermostat looks, it should be connected to the upper hose (the hose that has coolant flow in the direction from the radiator to the engine block). Most conventional engines have it there (my Camaro does). I bought the C only a few months ago and haven't had a chance to play with the NZ engine, but this summer I will be doing a full visual inspection on the engine. See photo attached from RockAuto.com (this is where I buy all my parts or use it to get OEM part #'s).
  8. strategy400
    strategy400 New Member
    25
    Victorville, CA.
    2015 Prius c
    So it's been about a year, but, I'd do a cooling system pressure test. Then I'd pull the spark plugs and have a look at them and down in the cylinders. If any of them is shiny clean you may have a head gasket issue, although I'd think there would be a CEL for misfire. Pull any codes. Check the oil dipstick and cap for evidence of coolant in the oil. Check exhaust for white smoke. Purchase a block test kit at an auto parts store and check for exhaust gasses in the radiator. If you can rule out a head gasket issue or crack then check the previously mentioned items, with the addition of radiator fan function.
  9. sam spade 2
    7,035
    2,801
    2017 Prius c
    Way, way, WAY overkill and mostly a waste of time IF.......heat coming out of the vents when not wanted is the ONLY symptom.
    KISS
  10. strategy400
    25
    Victorville, CA.
    2015 Prius c
    Wow did you even read OPs post? The car has overheated.
  11. sam spade 2
    7,035
    2,801
    2017 Prius c
    My most humble apologies.
    Somehow I thought this was the "heat coming out the AC vents" thread.
  12. Lukey51
    Lukey51 Active Member
    204
    108
    TN
    On a well maintained C with 109k miles, should I replace the thermostat?
    I've never had over heating and just flushed both parts of the cooling system.
  13. strategy400
    25
    Victorville, CA.
    2015 Prius c
    I'd feel better with a new one. Probably should have done it while the coolant was drained. Use an OEM part. Never cheap out on a critical part.
    Lukey51 likes this.
  14. Lukey51
    204
    108
    TN
    I recognize this part now. That looks like the engine block drain under the retaining clip with the 1/4" hose attachment to it. It looks like it would be a pain to replace.
  15. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    The C does not have a thermostat. Temps are controlled by the electric water pump via variable speed.
  16. Lukey51
    204
    108
    TN
    But who's to say a new one will work at all?
    If the car is maintained properly, IMHO the original thermostat should last the life of the car.
  17. sam spade 2
    7,035
    2,801
    2017 Prius c
    See post #15.
    The thermostat is NOT the problem......because there isn't one.
    Now, there is at least one coolant temperature sensor.......but water pump failures seem fairly common.
    HybridEnjoyer and Tim Jones like this.
  18. Lukey51
    204
    108
    TN
    That's news to me on these Prius C forums as far as well maintained Prius Cs are concerned.
    Got a link to someone here or on other forums where their water pump failed prematurely in a well maintained Prius C?
    I'd be surprised if you found more than one of them, or even one of them.
    #18 Lukey51, Mar 20, 2020
  19. priusCpilot
    663
    210
    LA
    The common water pump failures Im aware of are on the Gen 2 Inverter pumps. They updated that pump years ago and going forward they have been better. The C also runs both an electric inverter coolant and engine coolant pump. The inverter pump is also a variable speed pump where as the Gen 2 pump runs continuously at 1 speed. This is why the Gen 2 pumps die quicker since they always run.
    I have been also thinking about when to replace these pumps my self? I don't want them to die 100s or 1000s miles away from home on a road trip? Maybe at 200k miles just both to be on the safe side???
  20. Lukey51
    204
    108
    TN
    IMHO these parts are meant to last the life of the car, if your car is well maintained. If you go to all the expense and effort to replace this part, and then what if it fails anyway and you end up removing a perfectly good water pump and replacing it with one that's defective?
    But if your car has a lot of after market modifications then I can't speak on that.
