Help, Please.... how to remove hatchback?
Discussion in 'Gen 2 Prius Main Forum' started by moredes15, Jun 29, 2009.
  1. moredes15
    moredes15 Junior Member
    30
    I wanna tint the windows in the hatchback, but of course, it's a real pain "upside down"... so I'd like to remove the hatchback so I can do it on a table, etc.
    I see that I have to remove the hinge bolts and the struts, but what do I need to do about the two rubber "boots" next to the hinges? Can anyone help me? I'm afraid to pull them up without knowing what they're for... for all I know, they cover some kind of electrical harness..
    Thanks for your help!
  2. mrrobwood
    mrrobwood New Member
    Dracut MA
    do what i did, and pay someone to tint your windows, mine came out great. Why run the risk of breaking something?
  3. moredes15
    30
    I would, but the locals won't tint the rear window as dark as I'd like.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Those "rubber boots" as you call them carry ALL the wiring to the hatchback. There are connectors you could unplug to remove the hatch, but it's going to take some doing! Sounds like an interesting project, let us know how it works for you!
  5. dogfriend
    7,512
    1,188
    Carmichael, CA
    The hard part isn't getting the hatchback off - the hard part is getting it back on again (correctly). :madgrin:
  6. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    put your back seats down and then sit inside the trunk with the hatch closed. If you need more leg room, take out the storage compartment and the spare tire.
  7. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    I thought tinting the rear hatch window was fairly easy compared to the doors. I just took the plastic frame off to get the edges, and stood at the rear bumper with the hatch all the way open, making the work surface right in front of me. I used a pre-cut tint kit from eBay, so the hatch window film was one piece.
  8. patsparks
    10,664
    567
    Adelaide South Australia
    Just paint the window black.
    Or use legal tint.
  9. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    Unless you are capable of doing a professional quality tint job, I would not recommend removing the hatch to DIY. That's a HELL of a lot of work if it's even feasible. And if you can't do it with professional quality, it will show.
  10. Qlara
    Qlara New Member
    488
    This will be the best approach to tint the hatch glass.
    Attempt to remove the hatch just for tinting is OVERKILL.....you'll have a lot more troubles screwing the thing back on than darkening it.
    Imagine how are you gonna hold the hatch while bolting it back on, and the alignment to the latch...etc. Factory has special rig to do this job, you'll need 2-3 extra guys just to holding it.
