Help please part dos: HV Battery Problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DigDoug, Jun 22, 2022.
  1. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    Had the following codes come up today as I was out for a drive
    P2023 Battery Block 13 becomes weak
    Had this under Confirmed Trouble Code and 1 Pending Trouble Code
    1 Radar or Hybrid Control Code
    P3000 Status: CURRENT/HISTORY- Battery Control System
    My 2009 Prius has 231030 miles and I installed a New Prius Battery around 170000. I am planning on going to Missouri from Pennsylvania in a few days, what advice can you all give me? Thank you all in advance.n
  2. JC91006
    16,923
    8,634
    where did you get your New Prius battery? Curious how many years you had it
    SFO likes this.
  3. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    It was installed on Nov 20 2019 and it is from New Prius Batteries LLC. Sorry about the lack of information. I guess it wasn’t a “New Prius” battery but I bought it from that company.
    donbright likes this.
  4. JC91006
    16,923
    8,634
    wow interesting only 3 years old. You should reach out to them and see what they can do for you. It seems like a failed module
  5. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    To elaborate, I had to replace the MAF sensor recently and was driving in 88 degree heat this afternoon without the air on and I got the red triangle, VSC and check engine light on the dash. Along with the exclamation point inside of the circle. Drove around four miles home and posted soon after.
  6. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    I have seen them an email and am awaiting a response. I think it was 61000 miles or less. This is really cramping my plans for vacation.
  7. JC91006
    16,923
    8,634
    That's the unfortunate thing you'll face when you go away from OEM quality. These aftermarket batteries will not have the same quality as the original OEM which normally last 10+ years
  8. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    At the time I could not justify the cost. I guess I mark it down under lessons learned? I can say that I have been extremely pleased with them so far. What stinks is that we were leaving on Sunday. I guess the WWI memorial and museum along with War Remains can wait.
    Limey Geoff likes this.
  9. JC91006
    16,923
    8,634
    The reviews on this product has been very positive but there is no word out on the longevity of this product. I think you're the first I've read on the failure of this new battery. I think 2019 was about the time this product first sold.
  10. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    AHH I was the Guinea pig, well I guess that is fine. Not bad mouthing as they haven’t been given time to respond. I know during install the emails between us were answered quickly I should not complain. The car is my favorite with 42 mpg and a lead foot I am happy
  11. PriusCamper
    PriusCamper Senior Member
    13,335
    5,395
    Pacific Northwest, USA
    As always the quality of material defines its success... Project Lithium is 7 years into research in their aftermarket packs and still no issues with earlier failure than OEM. And when you use battery chemistry 1/4 century newer than Toyota & New Prius Battery uses you can expect a great deal of performance improvements. Just one of dozens of examples is NiMH is rated for 700 to 1000 cycles and LiFePo4 is rated for 5K cycles.
  12. JC91006
    16,923
    8,634
    I think Project Lithium is even newer than NPB and it costs more than proven reliable OEM. Not sure that's a great deal. And who has actually gone through and used up a new replacement OEM battery? I think by the time the 2nd battery fails, the car would be a complete mess inside and out, nobody would want it after that. No need to invest into a 3rd battery at the point.
  13. PriusCamper
    13,335
    5,395
    Actually the days of OEM replacement prices being less than Project Lithium are ending... I've been able to sell these packs for that reason alone. As in Florida briefly got down got down to $1400 range for OEM and $1600 range was common for past few years, but when I checked a couple months back in PNW the Portland area were out of stock with price of $2K and in Western Washington Stealerships with a pack in stock were $2500 to $4K range. Meanwhile Project Lithium went from $2100 up to $2300, or at least once they're back in stock. And by then how many back orders for OEM packs will there be? Two months ago a Toyota Stealership told me he was only seeing 5 remaining OEM packs in US warehouses...
  14. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    While I am interested in the Project Lithium due to lack of availability, for right now I am thinking NPB is my best option. OEM is not readily available from what I have found. I was wondering if anyone had any opinions on the codes and if they could have been caused by it being one of the hottest days of the year in my area and my not having the AC on. Normally I run the AC constantly when it is over 70 degrees.
  15. Tombukt2
    Tombukt2 Senior Member
    13,764
    2,491
    Durham NC
    I will be the one to report on that in about 300,000 mi My first battery made 20 years and 200 30 or 40,000. So I'm expecting this replacement to do about the same with minimal for us and if it does my car will be at about $650,000 about when it fails and I'll let you know what I'm going to do then probably not much as I should probably not be driving we will see we will see
  16. JC91006
    16,923
    8,634
    Running the AC can help cool the battery but if it's a well engineered battery, a little heat shouldn't affect it when it's only 3 years old. You might just be the lucky one to pick up one with a faulty module. It can happen, but if many users start having this problem, then it might just be a design/quality issue with the battery itself.
  17. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    Hopefully I was the only one with this problem. I like the interactions between myself and the company well enough that I almost placed an order from the car when I saw the dash light up. It is with more time passing that I allow myself to get irritated about it.
  18. bisco
    52,693
    what reader are you using, could it be in error?
  19. DigDoug
    DigDoug Member
    82
    25
    Pennsylvania
    Blue Driver
  20. PriusCamper
    13,335
    5,395
    In my experience the weak point in cylindrical NiMH modules is how the cells are connected to each other. I once was reconditioning a really early in the production run of after market Honda pack made by Bumble Bee battery in Portland, OR and the cells were connected to each other by a technique that cause two modules to explode during discharge because that connection failed. I wasn't injured, but if I had been near them when they exploded I could of been.
