Help please
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Darel, Jan 3, 2017.
  1. Darel
    Darel New Member
    Tennessee
    2005 Prius (engine code PO A60 drive motor A phase U current Low ) the triangle light is on and the car will stop pulling let it set and it will take gear again for about 20 miles or so .. any help on this is appreciated
    #1 Darel, Jan 3, 2017
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Sorry, can't help with your problem. But I'll point out that you've posted this in the Prius C forum - you may have a better chance of getting a response in the Prius forum.
    49,507
    welcome!
    what did you read the code with?
  4. Darel
    Darel New Member
    Tennessee
    A mac obd 2 scanner
  5. bisco
    49,507
    you might need tech stream for more detailed diagnosis, and toyota tech info for troubleshooting.
    how many miles on her?
